May 02, 2024, 10:49:40 PM
Welcome Guest, Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
Home
Store
Calendar
Members
View the memberlist
Search For Members
Login
Register
All
Current Board
Current Topic
Vehicle Specific
Toyota Pickup/4Runner Tech 1979-95
1979-1983: How-To Guides
(Moderators:
OOPS
Cheesemaker
Topic:
Leaf Spring Removal (first front, then probably back)
Pages: [
1
Go Down
Print
Author
Topic: Leaf Spring Removal (first front, then probably back) (Read 2271 times)
83_P/U_4x4
Rock Crawl'n
Turtle Points: 1
Member since Jul '18
Dreaming of Crawling
on:
Apr 27, 2019, 06:28:59 PM »
Hey Everyone, I’m trying to remove the front leaf spring on my 1983 and the shackle and front bolt are not budging. I dropped the axle and tried to take some weight off the springs to then be able to remove the bolts but nothing is moving more than an inch.
If there’s something I’m missing then I’d love some help or insight that could help me to remove them so I can get some new springs in that would be great!!
I’ll also update with any developments I find and make.
Logged
gnob
4WD Legend
Turtle Points: 486
Member since May '02
Re: Leaf Spring Removal (first front, then probably back)
Reply #1
on:
Apr 27, 2019, 07:08:17 PM »
Lots of wd-40, some patience and a BFH.
Consider just cutting and replacing.
Logged
hold this. . .
Gold Turtle Award
Turtle Points: 2872
Member since Sep '05
Reply #2
on:
Apr 27, 2019, 07:44:14 PM »
I like pb blaster better, and a torch if you have it. are you using standard hand tools, or an impact wrench?
I have a 20v dewalt xr brushless motor impact, and it does like 600 foot pounds of torque with like 1200 ft pounds of breakaway torque. it can do some amazing things
Logged
Snowtoy
The 2.5K Group
Turtle Points: 1403
Member since Sep '03
Reply #3
on:
Apr 28, 2019, 09:53:28 AM »
Yep, PB let it soak in over night, if that don't do it, hit it with some heat.
Or, just go at it with good socket, breaker bar, and long piece of pipe, you will either break the nut loose, or break the bolt.
Logged
The money pit
'87 Supra resto/mod
OVRAROK
Silver Turtle Award
Turtle Points: 26852
Member since Dec '10
Reply #4
on:
Apr 28, 2019, 02:32:54 PM »
I would take a sawzall to the head, of either the nut or bolt, whichever is easy to get to. Cut as close as you can. Then a simple breaker bar should snap what's left. Then pound out whatevers left.
Logged
83_P/U_4x4
[OP]
Rock Crawl'n
Turtle Points: 1
Reply #5
on:
Apr 28, 2019, 03:09:01 PM »
I should clarify, all the nuts are removed, it’s the rubber bushings on the shackles and front bolt that won’t move, I’ve used lubricating/ 3-1 oil a few times but it still won’t move
Logged
OVRAROK
Silver Turtle Award
Reply #6
on:
Apr 28, 2019, 04:03:02 PM »
I would drill a slight pilot hole on ends of bolts. With nuts removed. Air hammer with the correct tip should push them out..
Logged
83_P/U_4x4
[OP]
Rock Crawl'n
Turtle Points: 1
Reply #7
on:
May 22, 2019, 04:09:26 PM »
Thanks everyone. I'm gonna try to use an air hammer tonight on at least on of the bolt to see if I can make some progress.
I'll make sure to update the thread when I do it.
Wish me luck
Logged
redneckcustoms13
The 2.5K Group
Turtle Points: 7674
Member since May '15
Reply #8
on:
May 23, 2019, 08:47:25 AM »
Are you removing to replace the bushing or the entire spring? Either way, heat it up with a torch and melt them boogers out.
Logged
01 double cab hunting truck
06 tacoma street truck
Pages: [
1
Go Up
Print
Vehicle Specific
(Moderators:
OOPS
Cheesemaker
Topic:
