Author Topic: 80 series axle mods help  (Read 2324 times)
sjelite
  • Male Posts: 93
  • Member since Aug '11
« on: Apr 23, 2019, 09:25:03 AM »
Hello All
I'm looking for advice. I picked up a set of LC 80 series axles and planning to swap them onto my 1st gen. My questions are in regards to how to clean up the 80 series axles, removing all the tabs and spring perches, I have access to a plasma cutter, welder and of course an array of angle grinders.
Questions are:
 Seals: Is it possible to go through the clean up procedure and save the inner seals etc wile being installed?
Oil: Should I drain the oil prior to plasma or grinding, or leave oil in and drain after?
Welding of new tabs; Weld on tabs and perches with oil in the axle or remove oil? Can new  perches and tabs be welded on with axle complete.
Strip Down: should I just plan on completely striping down the axles to the bare housings?
Thanks for reading
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
Re: 80 series axle mods help
« Reply #1 on: Apr 24, 2019, 07:59:07 AM »
Yep!!
cbeers
  • Turtle Points: 4347
  • Member since Jan '14
« Reply #2 on: Apr 24, 2019, 10:36:15 AM »
i wouldn't worry about the gear oil either way but i drained mine.
go slow. like 2" beads at a time.
rotate where you weld so you don't concentrate too much heat in a single area.
strip it down and build it back up.
replace the seals....cheap and the last thing to get to when tearing down.
get gloves and towels it's a pretty messy project but rewarding when done.
my build has pics.
CB
sjelite [OP]
  • Male Posts: 93
« Reply #3 on: Apr 24, 2019, 11:53:52 AM »
thanks guys
and thanks CB ill check out your build picks
sjelite [OP]
  • Male Posts: 93
« Reply #4 on: Apr 26, 2019, 07:36:17 AM »
One other question
Does anyone know if  drive line length be the same when I switch from mini to 80 series
CrazyYota
  • Turtle Points: 92
  • Male Posts: 1,073
  • Member since Oct '05
« Reply #5 on: Apr 26, 2019, 09:31:00 PM »
I think your going to have bigger problems than drivelines. Good luck.  :beerchug: and post pictures.
joeyf
  • Turtle Points: 848
  • Member since Dec '06
« Reply #6 on: Apr 26, 2019, 10:27:08 PM »
Definitely strip them down to the housing before cutting and welding. I have done a couple 80 swaps, if you have any other ? along the way post them up.
joeyf
« Reply #7 on: Apr 26, 2019, 10:38:10 PM »
One other question
No major mods needed if you stick them in the stock location. The only one is drilling new holes in the rear drive flange or swapping it out for the one that's on the truck right know.
sjelite [OP]
  • Male Posts: 93
« Reply #8 on: May 02, 2019, 07:27:59 AM »
Thanks Joeyf
Ill post some pictures when available.  Do you have any 80s swap build pictures on this forum? Do you drive any of the 80s swapped mini trucks on the street? If so were there any issues with the rear dive line angle and the passenger side rear dif angle?
joeyf
« Reply #9 on: May 02, 2019, 10:35:22 AM »
Sorry no build on them. Yes one of the rigs is a DD,  the offset does nothing to the drive line. Just set the pinion angle to what ever drive line you are going to use, CV or no CV.
sjelite [OP]
  • Male Posts: 93
« Reply #10 on: May 02, 2019, 01:09:15 PM »
Awesome man thats what i wanted to hear, thanks!
Last post Mar 02, 2007, 07:20:59 PM
by joeshmo
Last post Feb 08, 2011, 06:39:22 PM
by Sparkplug
Last post Jan 23, 2012, 11:15:58 AM
by TacoRunner
Last post Jul 01, 2012, 02:20:40 PM
by REG535
Last post Apr 21, 2014, 12:51:26 AM
by zembalayan
