Author Topic: CA smog test aftermarket fuel cell  (Read 2138 times)
sjelite
  • Male Posts: 93
  • Member since Aug '11
« on: Feb 27, 2019, 12:06:15 PM »
Hello all
Looking to go 4 link and keeping my truck CA street legal and smog legal  1982 pickup 22re
Can i still pass smog inspection with my stock fuel tank removed and using an in bed /under bed custom fuel cell? Looking for an aftermarket one to install.
Also if i go 3rz in the future and need BAR inspection with the fuel cell be acceptable?
Thanks
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
Re: CA smog test aftermarket fuel cell
« Reply #1 on: Feb 27, 2019, 02:46:14 PM »
Depends on how smart the SMOG guy is, but the real answer is no!!
Snowtoy
  • Turtle Points: 1403
  • Male Posts: 2,583
  • Member since Sep '03
« Reply #2 on: Feb 27, 2019, 03:00:47 PM »
Seeing how the tech has to be able to test the EVAP system and cap for leaks, as well as not having a filler neck that prevents fumes from freely entering the air while filling up, I am guessing they don't.  Chances are you will need to run two types of tanks, a cell for the trail, and small tank with the oem fittings, neck, and cap for smog tests, as well as for any "green" or "by the book" LEO you encounter on the street.
sjelite [OP]
  • Male Posts: 93
« Reply #3 on: Feb 27, 2019, 03:27:51 PM »
I was thinking of putting the tank in bed and routing the filler neck out to the original fuel door. Building on what Snowtoy said.
I could possibly modify a stock fuel tank and make it small capacity tank and use a large auxiliary tank as my “main capacity tank”
Man…. All this fun plus the overpriced gas taxes.
Snowtoy
  • Male Posts: 2,583
« Reply #4 on: Feb 27, 2019, 08:01:48 PM »
On top of artificially inflated gas prices, and the cost of the additives that allegedly burn cleaner while causing you to burn more fuel per mile.
If there is room for a tank behind the cab, the Corolla's from the same yrs had 13-16 gallon tanks, the Civic had an 11, and the Escort a 10, so you should have factory alternatives to cutting down the stock tank or buying a custom made one.
sjelite [OP]
  • Male Posts: 93
« Reply #5 on: Mar 14, 2019, 12:10:35 PM »
good to know!
Thank you
Last post Mar 31, 2005, 07:34:15 PM
by alwayzbroken
Last post Oct 01, 2006, 01:30:04 AM
by kneedownnate
Last post May 17, 2009, 07:26:19 AM
by Redbeard3261
Last post Jan 29, 2012, 08:20:20 PM
by bigarms23
Last post Jun 14, 2021, 02:41:07 PM
by RustyToy
