Author Topic: Marlin Crawler's New Rock Crawling Long Travel IFS Suspension System (#RCLT)  (Read 113161 times)
canadian bum
  • Turtle Points: -1
  • Male Posts: 79
  • Member since Aug '10
Thank you for all the nice replies everyone. It's been a long summer for me as I broke two ribs early last month which has slowed down my productivity. No major updates as of yet, however I plan to submit all drawings for V3 (hopefully the last) prototype this Friday to begin building it in about 2 to 3 weeks (time it takes to laser cut as well as build V2 jigs). I'll be posting more once that process begins. I am definitely behind with the Standard RCLT kit production unfortunately...
Thanks for the reply. I do prefer the idea of a double sheer setup but am not committed on the TRE of choice yet. What is the source on that tie rod end? I'd like to review it's specs. As for the bend angle, I have designed the steering arm with a 10-degree slant which could be increased more if needed.
Currently and in order, the downtravel limits are:
#1: The inner CV joint. (RCV cannot improve this any further so the only option is a diff drop which defeats a major purpose of RCLT)
#2: The MarRack ITR joint. (Easy to improve this design)
#3: The TRE jam nut interfering with the steering arm. (Easy to improve this by adding more than the 10-degree angle in the steering arm)
#4: Finally, the heim joint max bend angle. (Same as #3: Easy to improve this by adding more than the 10-degree angle in the steering arm)
So downtravel is already limited by the axle shaft long before the heim joint. I've discussed a few different axle designs with RCV including the use of a slip-joint mid-shaft, which they actually designed for UTVs but the added cost for this was very high (on already one of the most expensive parts) and even despite the use of roller bearings still encountered too much friction resulting in other issues. The concept is to ditch the 30-degree max angle inner slip joint and use the fixed (non-slip) 43-degree angle outer CVs at both out-board and in-board locations... The end result would have a quite large diameter meaning the spacing of the RCLT V-Groove would need to be increased which would result in a major loss to ground clearance...
Ideally, yes. Same for the axle shaft. But it's not easy fitting 40s haha My ride height is, however, about 0.75" taller than before, which I do not like, so once I get healthy and resume working on the Taco I plan to lower it a bit which will help level those parts out.
Regards,
Hey Mike, sorry for not getting back to you sooner. Source for the TRE is Evolution Machine and Fabrication, EMF out of Canada. Clayton builds some really high end parts. https://www.emfrodends.com/
I use all his joints in my builds and some custom steering parts as well.
78 FJ45 Now going to be 1HD-T on 80 series axles / http://forum.ih8mud.com/fj45-owners-club/107069-fj-45-build-up-restoration.html
79 BJ40 Going to be a 1HD-T on 80 series axles / http://forum.ih8mud.com/40-55-series-tech/266976-bj40-build-up-resto.html#post4143046
06 Taco DC Daily driver, Dana 44 HP front, pro comp rims and 345/75R16 BFG KM2, Rear ARB locker, and All-pro plate bumper. Crashed.... now building an 05 Taco on tons and 4.7 V8 swap.
Rockdwg
  • Turtle Points: 72
  • Male Posts: 16
  • Member since Dec '13
so just out of curiosity with this RCLT kit what size lift would a guy need for the rear??  my current Tacoma is a 08 DCSB TRD off Road. only thing done to it is a leveling kit and a C4 plate bumper
Wainiha
  • Turtle Points: 743
  • Male Posts: 1,170
  • Member since Jan '12
When you finalize the design and put it up for sale will Marlin Crawler be available to do the installation?
2000 3.4L xtra-cab Tacoma.
Icon C/Os
Marlin 1200lb. clutch
Marlin short shifter
FLOODED...GONE
2005 4.0L xtra-cab Tacoma
FLOODED...GONE
2012 4.0L xtra-cab 4x4 Tacoma
Automatic...Don't shoot...
 King resi C/O
and Total Chaos UCAs
dankunz
  • Member since Nov '13
*poke poke*  I need something to do this winter :)
loveatfirsttaco
  • Turtle Points: -22
  • Member since Aug '19
Hate to be a pain but it looked like things were so close to production.  Can you give us a new timeline or update on RCLT?  I've been saving my money to buy this over other LT options.
Thanks
Mecey
  • Turtle Points: 22
  • Member since Oct '19
Thanks
Also ready to pull the trigger. Any updates?
dankunz
It snowed in a lot of the country. Does that mean it's winter?  Winter 2019/2020 production!  woohoo!   :gap:
canadian bum
  • Turtle Points: -1
  • Male Posts: 79
Any release schedule for the standard kit? Testing being done? Pricing? Thinking of something for the 4Runner...
Wainiha
  • Male Posts: 1,170
Really?  I already have one..
 :therethere:.....I wish...
Icon C/Os
FLOODED...GONE
FLOODED...GONE
 King resi C/O
Wainiha
  • Male Posts: 1,170
Where did u get your fiberglass fenders?
Icon C/Os
FLOODED...GONE
FLOODED...GONE
 King resi C/O
DMG
Most of the suspension on a Tacoma is really similar to a 1st gen tundra.  Will you make a kit for the tundra?  Or will it be adaptable to a tundra?
dankunz
Thanksgiving done!  I need a winter shop project!  This seems perfect :)
loveatfirsttaco
Ok Big Mike.  Give us some good news....   :crossed: :crossed: :crossed: :crossed:
Wainiha
  • Male Posts: 1,170
What's the estimated price? For the whole setup including cam bolt reinforcement etc.  I need to start saving....Oh shocks too.
Icon C/Os
FLOODED...GONE
FLOODED...GONE
 King resi C/O
4stair
  • Member since Mar '07
would love to see what one looks like on an fj cruiser, how much tire it will clear, and a ball park price so i know if i am truly interested in it or if i am looking for a full time wheeler instead.
Mecey
  • Turtle Points: 22
I think we should all start a betting pool on eta and price.
I’m saying 9k and April.
T-Revv
  • Turtle Points: 722
  • Male Posts: 278
  • Member since Apr '17
  • Crawlin at work, Crawlin on the trails. best life.
See here: https://www.marlincrawler.com/suspension/rclt/rclt-hd
Release group 1:
  2005+ Tacoma
Release group 2:
  2003+ 4Runner
  Lexus GX470
  FJ Cruiser
Release group 3:
  1995-04 Tacoma
  1996-02 4Runner
Release groups 1 and 2 are getting very close, should be releasing this winter, hopefully around February (watch two of the test vehicles running in in KOH).  Group 3 will take a different design that is a ways off.
"I dunno I just woke up from a lil nap, it's a lil dark but you guys silly? I'm still gonna send it."
T-Revv
  • Male Posts: 278
At this time Marlin Crawler will not being doing installations.
dankunz
I’ll be installing mine.  Send it!!!
Mecey
  • Turtle Points: 22
Release group 1:
  2005+ Tacoma
Release group 2:
  2003+ 4Runner
  Lexus GX470
  FJ Cruiser
Release group 3:
  1995-04 Tacoma
  1996-02 4Runner
February release as in I could see one in February or as in I could order in February but would have a 8-12 week build time?
dankunz
I left messages etc.  I would like to get mine on in time for an event in March.
Need some response!  Happy New Year!
Release group 1:
  2005+ Tacoma
Release group 2:
  2003+ 4Runner
  Lexus GX470
  FJ Cruiser
Release group 3:
  1995-04 Tacoma
  1996-02 4Runner
T-Revv
  • Male Posts: 278
Hopefully we will have several on the shelf ready to ship by end of February, beginning of March.  This will not be a built to order item like a Tcase or Transmission which is what has the 8-12 week lead time.
Who are you leaving messages with? As far as getting one in March, we are trying to get them out by that point, but nothing is guaranteed.  Unfortunately there are things that can delay this production that are out of our control. Manufacturing delays are the nature of the beast when dealing with custom machined parts like these.  We are at the mercy of machinists, software and computers, shop time and scheduling, milling machines and laser cutters, material availability, and on and on.  With so many variables its impossible to give a for sure date, but our rough ETA at this time with no hold-ups would be the end of February beginning of March.
dankunz
Wainiha
  • Male Posts: 1,170
I would not be ready until I moved to Oregon Could anybody recommend a good shop up there?
Icon C/Os
FLOODED...GONE
FLOODED...GONE
 King resi C/O
OTO Phil
  • Turtle Points: 1018
  • Male Posts: 682
  • Member since Jan '16
  • Owner of Offroad Toy Outfitters
    • Offroad Toy Outfitters
What part of Oregon?
Sent from my LM-G710 using Tapatalk
Wainiha
  • Male Posts: 1,170
I"m thinking about 1 to 2 acres in the Pacific City area.  And an additional 40 acre parcel in Klamath(It's cheap).
Icon C/Os
FLOODED...GONE
FLOODED...GONE
 King resi C/O
TheDragonChk
  • Member since Nov '19
Do you have pricing available yet?
T-Revv
  • Male Posts: 278
Not an exact cost yet, too many variables still not accounted for to know what we have into it in order to make a reasonable price for it.  However at this time, once you include the RCV Axles, the MarRack, and Coilovers, plus the kit you will be somewhere in the 8-10k area.  obviously if you already have your coilovers or RCV axles than you can deduct that, as they will be sold separately.
OTO Phil
  • Male Posts: 682
I don't know of any shops in those areas. If you want to bring it up to the Portland/Vancouver area, there's a few shops I'd highly recommend. Feel free to message me
OTO Phil
  • Male Posts: 682
Are you planning on selling the MarRack separately?
Last post Dec 21, 2005, 12:15:25 PM
by robinhood4x4
Last post Sep 07, 2006, 05:34:31 PM
by pirate mafia
Last post Apr 11, 2020, 05:59:27 PM
by Slabzilla
Last post Apr 19, 2019, 07:42:38 AM
by BigMike
Last post Jul 17, 2020, 05:09:30 PM
by emsvitil
