Thank you for all the nice replies everyone. It's been a long summer for me as I broke two ribs early last month which has slowed down my productivity. No major updates as of yet, however I plan to submit all drawings for V3 (hopefully the last) prototype this Friday to begin building it in about 2 to 3 weeks (time it takes to laser cut as well as build V2 jigs). I'll be posting more once that process begins. I am definitely behind with the Standard RCLT kit production unfortunately...Thanks for the reply. I do prefer the idea of a double sheer setup but am not committed on the TRE of choice yet. What is the source on that tie rod end? I'd like to review it's specs. As for the bend angle, I have designed the steering arm with a 10-degree slant which could be increased more if needed.Currently and in order, the downtravel limits are:#1: The inner CV joint. (RCV cannot improve this any further so the only option is a diff drop which defeats a major purpose of RCLT)#2: The MarRack ITR joint. (Easy to improve this design)#3: The TRE jam nut interfering with the steering arm. (Easy to improve this by adding more than the 10-degree angle in the steering arm)#4: Finally, the heim joint max bend angle. (Same as #3: Easy to improve this by adding more than the 10-degree angle in the steering arm)So downtravel is already limited by the axle shaft long before the heim joint. I've discussed a few different axle designs with RCV including the use of a slip-joint mid-shaft, which they actually designed for UTVs but the added cost for this was very high (on already one of the most expensive parts) and even despite the use of roller bearings still encountered too much friction resulting in other issues. The concept is to ditch the 30-degree max angle inner slip joint and use the fixed (non-slip) 43-degree angle outer CVs at both out-board and in-board locations... The end result would have a quite large diameter meaning the spacing of the RCLT V-Groove would need to be increased which would result in a major loss to ground clearance...$$$$Ideally, yes. Same for the axle shaft. But it's not easy fitting 40s haha My ride height is, however, about 0.75" taller than before, which I do not like, so once I get healthy and resume working on the Taco I plan to lower it a bit which will help level those parts out.Regards,BigMike
Hate to be a pain but it looked like things were so close to production. Can you give us a new timeline or update on RCLT? I've been saving my money to buy this over other LT options.Thanks
What's the estimated price? For the whole setup including cam bolt reinforcement etc. I need to start saving....Oh shocks too.
See here: https://www.marlincrawler.com/suspension/rclt/rclt-hd
When you finalize the design and put it up for sale will Marlin Crawler be available to do the installation?
Release group 1: 2005+ TacomaRelease group 2: 2003+ 4Runner Lexus GX470 FJ CruiserRelease group 3: 1995-04 Tacoma 1996-02 4Runner Release groups 1 and 2 are getting very close, should be releasing this winter, hopefully around February (watch two of the test vehicles running in in KOH). Group 3 will take a different design that is a ways off.
February release as in I could see one in February or as in I could order in February but would have a 8-12 week build time?
I left messages etc. I would like to get mine on in time for an event in March.Need some response! Happy New Year!
I would not be ready until I moved to Oregon Could anybody recommend a good shop up there?
Hopefully we will have several on the shelf ready to ship by end of February, beginning of March. This will not be a built to order item like a Tcase or Transmission which is what has the 8-12 week lead time.
Do you have pricing available yet?
I"m thinking about 1 to 2 acres in the Pacific City area. And an additional 40 acre parcel in Klamath(It's cheap).
Not an exact cost yet, too many variables still not accounted for to know what we have into it in order to make a reasonable price for it. However at this time, once you include the RCV Axles, the MarRack, and Coilovers, plus the kit you will be somewhere in the 8-10k area. obviously if you already have your coilovers or RCV axles than you can deduct that, as they will be sold separately.
Started by MiniSimp Toyota Tacoma/4Runner/T100/Tundra/FJ Cruiser 1995+
Started by Destruct O Toyota Tacoma/4Runner/T100/Tundra/FJ Cruiser 1995+
Started by BigMike « 1 2 » Chit Chat Camp
Started by BigMike Off-road Videos
Started by emsvitil Chit Chat Camp
