I was originally looking at the 1200 but was thinking about going with the 1600 because it's not much more expensive also running 31 10.5s if that matters any
Practice your clutchless shifting occasionally
Hey e.... so how do I practice clutchless shifting while rockcrawling? Gnarls.
Notpossible907 thanks for the info yotashop has an aisin clutch for close to what my last one costed I may not change it due to I only have about 20K on my current clutch but it'll be a good thing to have one in the shop should I need it down the trailDoes anybody know how many miles is the typical lifespan of the master and slave cylinder the previous owner of my 4Runner replaced the master cylinder in 2008 and I replaced the slave cylinder when I replaced the clutch in 2011
That's what starting in gear with the starter is for.
Gnarls what I meant by having a clutch in the shop down the trail is having a clutch lying in my shop that way when it goes out I can just put my truck on the lift and change it due to the fact the w56b transmission it's the lightest transmission I have ever dealt with I probably could change my clutch out on the trail in about 2 hours
I had the Marlin 1600 lb clutch in my 89 pickup 22RE and 31" tires. I did not find it any more tiring to use than the stock replacement clutch I had previously. I would not change your clutch at 20k miles unless it look damaged or soaked with oil on inspection. A decent clutch will last over a 100k miles under regular usage. Of course that will vary with the driver and how much they abuse it. The cheap stock replacement failed on the trail with about 95k miles. (friction material separated from the clutch plate and had zero bit at the end). Ended up with an 80 mile tow back home.
I remember when I had a 3200 lb. L-88 pressure plate and clutch disc installed on my 1967 Vette. The difference in clutch pedal pressure was VERY noticeable. My little 5ft 2" girl friend loved to drive it, but not in LA bumper to bumper traffic. Gnarls.
I hope She was smoking hot Gnarly?Would have to be to drive My 1967 Vette
We need a clutch for 85 SC LB worktruck.For some reason, 300k is going with the 22REP clutch. Maybe this post will change his thinking. I wanted MC.
Started by wrenchtech Engine
Started by Zoomschwortz Toyota Pickup/4Runner Tech 1979-95
Started by BigMike New Announcements and Info
Started by vikingsven Parts For Sale
Started by gdmcondev New Member Check-In!
