Never purchased steel stock before so chime in if you think I was ripped off!
Picked up the stock for this today. $100 cut from the supplier. 12 cuts.
I think you can avoid bowing if you tack one side, then the other let cool. then do the bead.
I think it may have been nearly unavoidable in this case without pre shaping the tubes. There were a total of 28 welds on the same side of each support tube.
I attempted to straighten the supports out with a handheld MAPP torch. Definitely not hot enough...
Is it real MAPP or MAP Pro?
MAP Pro
Thanks for all the wisdom! Definitely learning alot as I go along.I don't have an acetylene setup so I need to either:1) Get an acetylene setup2) Make a friend with an acetylene setup3) Use the underside of the supports for bead practiceWe'll see how patient I am before #3 happens.
It is a welding table, it should never see the amount of weight or force applied the welds to ever be an issue.
Started by bsilva132 Parts For Sale
Started by camoyota Parts For Sale
Started by NWyoat Trail Reports, Events, and Gatherings
Started by peacesells Arizona
Started by NCK4L Bumpers, Cages, and Tube Benders
