Author Topic: I want your opinion  (Read 7405 times)
vikingsven
  • Turtle Points: 144
  • Member since Jul '02
I want your opinion
« on: Jun 04, 2003, 03:47:06 AM »
I just priced a set of Alcan springs for my truck:
Front:
4" Lift. 1.5" Longer than Stk. Center Pin moved 1.5" forward.  $350/set.
Rear:
4" Lift. 12" longer than stock (59")  $450/set.
Thoughts?  :thud:  :.order: :.order: :.order: :beer:
« Last Edit: Dec 31, 1969, 04:00:00 PM by 1056988800 »
vikingsven [OP]
Re: I want your opinion
« Reply #1 on: Jun 04, 2003, 05:10:16 AM »
This may be a simple question for some, but considering this is my first swap I want to get it as close to right the first time through.
I plan to run 35's. Anyone think I'll have any clearence problems in front that can't be solved with mild sawzall action, or should I increase the spring lift??  :~~:
I was thinking I could fab longer shackles to adjust for lift/clearence.  :eek:
« Last Edit: Dec 31, 1969, 04:00:06 PM by -1 »
toyotaboy
  • Turtle Points: 238
  • Member since Sep '02
rest in peace Effay
01 taco needs, duals, front axle, linked rear, exo...
85 extra cab/cab for sale with efi harness. no drivetrain, will sell, make offer
vikingsven [OP]
« Reply #3 on: Jun 05, 2003, 03:50:01 AM »
Thanks...Saw that thread. :thumb: I'm really interested in others thoughts on my particular SAS plan, especially if someone has gone this route before, what they would do differently, tips, etc.  :.order: :thumb:
84runner
  • Turtle Points: 99
  • Member since Dec '02
« Reply #4 on: Jun 05, 2003, 06:24:17 AM »
Do u have a body lift?
vikingsven [OP]
« Reply #5 on: Jun 05, 2003, 09:41:09 AM »
No body lift. I'd rather not run one if I can help it. :crazy: They just don't appeal to me for some reason :reg:
Although if I had to, I'm not against running a 1" body lift.  :down:
mr4x42u
  • Turtle Points: 700
  • LOCKED AND LOADED
« Reply #6 on: Jun 05, 2003, 10:37:11 PM »
what year is your rig?something to think about is 84 and newer rig don't have the wheelwell space the 83 and older ones had..so a 2 in body lift is cool I think..With a two inch body lift if you are running a 4 runner,that will let you raise the fuel tank 2 inches.or in a truck too if you not already running a flatbed..I don't care what chicks say,,,INCHES COUNT!I think 3 inch body lifts are too much..They start to look funny..Two inch is my max..The other thing is to cut the cab corners and section them flat..I have tech on this somwhere..Its not that bad of a project..
vikingsven [OP]
« Reply #7 on: Jun 06, 2003, 03:41:38 AM »
1988. I'm not against hacking the fenders a bit. How much do you estimate I can remove from the front cab side fenders without it looking hokie, and before I should cut and section them flat??
mr4x42u
  • LOCKED AND LOADED
« Reply #8 on: Jun 06, 2003, 04:45:09 AM »
I cut my fenders a good 3 inches all the way arount in the front till I got to the back half of the fender,,thin I just took it down enough so it don't look hacked..The rear I only cut 1 inch..I did not want to cut and weld in a section to the inner fender well.not yet at least..But mine is a runner,,a truck you can go alot more I think..I only had an inch till the inner fender well..
84runner
  • Turtle Points: 99
« Reply #9 on: Jun 06, 2003, 10:09:45 AM »
mr4x42u lets see some pics of that please
vikingsven I pushed my fender wells all the way in to the body support and it don't look bad at all, just make sure u roll the seam the right way
vikingsven [OP]
« Reply #10 on: Jun 06, 2003, 10:49:32 AM »
84runner: PICS ?
Last post Jul 27, 2007, 08:46:09 PM
by Old Fart
Last post Aug 29, 2007, 11:25:52 PM
by jimbo74
Last post Nov 01, 2007, 09:53:25 AM
by Steve97TJ
Last post Nov 13, 2007, 03:57:16 PM
by 79coyotefrg
Last post Jan 25, 2008, 05:30:36 PM
by Plowking
