Do they make a 97 links timing chain for Toyota 22re engines. My brother-in-law rebuilt the engine with an older block. I'm not sure how much was machined off or if any was machined off. The chain tensioner came apart after the engine was rebuilt & ran the 5 months. Yes I've a new tensioner. The chain is so loose that the tensioner barely touches the chain. The tensioner is all the way out. The last chain was from Cloyer, i think that spelled right from O'reilley's.
I've a Toyota 22re engine that was rebuilt. The timing chain "jumped" off the top sprocket after working fine for 5 months. I've bought 3 different chains, but all are too long. The 96 links chain is to short & the 98 links is to long. Does anyone have any suggestions on "fixing" this?
The old chain as the chain from the engine that came in the truck? I'm not sure. I haven't looked at the engine this evening. Maybe I can take a look at it tomorrow.
The tensioner came apart & I think got caught in the chain to make it jump off the sprocket.
The chain that was working has 98 links. The chain came off(jumped) the top sprocket & went to the back side of the sprocket. I did take a look at the engine block, it does have the thing on the block that is circled. It has 22R stamped in the small area beside the block number(serial number)?
I've put the timing chain with 96 links on & with it on the passenger side chain guide & the chain tensioner cannot be installed. the chain is to tight & there is no slack in the chain to install the guide or tensioner.
The chain that was working has 98 links. The chain came off(jumped) the top sprocket & went to the back side of the sprocket. I did take a look at the engine block, it does have the thing on the block that is circled. [/b[It has 22R stamped in the small area beside the block number(serial number)?
Started by 2utadud General 4WD Discussion
Started by GoaT Engine
Started by wrenchtech Toyota Pickup/4Runner Tech 1979-95
Started by chevihemi Parts For Sale
Started by 84pickup Toyota Pickup/4Runner Tech 1979-95
