Author Topic: '91 22re Idles surge w/A/C on and brake pedal depressed.  (Read 1469 times)
Snowtoy
  • Turtle Points: 1403
  • Male Posts: 2,583
  • Member since Sep '03
« on: Jun 22, 2018, 12:44:54 AM »
Like the title says, the idle surges with the A/C on and brake pedal depressed.
Idle w/a/c off is about 800, turn A/C on and it jumps to about 1500, no issue until you depress the brakes, then the idle drops, rises moderately back to 1500, then drops.
I adjusted the A/C idle up screw, dropped the rpm's to 1200, same response, only slower for the rpm's to climb back to 1200, then drops to back to 8-900,.  I kept adjusting it a little at time, cycling the throttle, depressed the pedal,  until it stopped surging.  However, at the point it stops surging, when you turn the A/C off, and then back on, the rpm's drop, which was the issue I tried resolving last yr.
Now, the kicker is, if I use the throttle to raise rpm's to 1200 or 1500 with the A/C on, while the brake pedal is depressed, there is no surge like there is when the A/C idle up raises the rpm's.
I am I just not finding the sweet spot?
Snowtoy [OP]
  • Male Posts: 2,583
Yah, thought that as well as I have it usually set about 1k, except when being smog checked. I will mess with it again this afternoon/evening.
Snowtoy [OP]
  • Male Posts: 2,583
Might have the problem located, yesterday I messed with it again, and this time I couldn't get the idle to change until I had the idle up screw all the way out, checked the VSV, and it would open, but the ohms are out of spec., will replace and see what it does.
Last post Jan 20, 2006, 08:17:55 AM
by trax28to
Last post Oct 26, 2007, 01:40:58 PM
by toyotanner
Last post May 11, 2012, 05:57:36 PM
by Slolyfe
Last post Nov 08, 2019, 05:54:44 PM
by Gnarly4X
Last post May 30, 2020, 05:12:08 PM
by GreenYoterKrawler
