Author Topic: Gear oils being used  (Read 4972 times)
019854Runner
  • Member since Jul '14
« on: Apr 20, 2018, 05:29:08 PM »
Just to be sure, so the F/R Diffs, transmission, Marlin Doubler all uses 80W/90 Gear oil? 1985 4runner with Marlin Doubler.
redneckcustoms13
  • Turtle Points: 7674
  • Male Posts: 2,513
  • Member since May '15
Re: Gear oils being used
« Reply #1 on: Apr 20, 2018, 06:15:04 PM »
Yes.
01 double cab hunting truck
06 tacoma street truck
SqWADoosh
  • Turtle Points: 10966
  • Male Posts: 2,417
  • Member since Oct '14
« Reply #2 on: Apr 20, 2018, 06:22:31 PM »
MT-90 in the trans and cases.
  • Turtle Points: 1174
  • Male Posts: 5,058
  • Crawlin with Marlin
« Reply #3 on: Apr 20, 2018, 09:06:49 PM »
Is better but not required. I know why for the transmission with GL-4 and syncros, but why is it superior in the t-case?
SqWADoosh
  • Male Posts: 2,417
« Reply #4 on: Apr 21, 2018, 04:28:03 AM »
I run same in both in case of seal failure causing migration and for ease of using the same. My cases always ran great and quiet using it.
  • Male Posts: 5,058
« Reply #5 on: Apr 21, 2018, 08:33:41 AM »
That makes sense. I have never spent the money for Redline anywhere but the transmission and even topped that off with the Valvoline blend I used everywhere else.
  • Turtle Points: 5134
  • Male Posts: 4,256
  • Member since Jun '16
  • 4-wheeling vicariously.
« Reply #6 on: Apr 21, 2018, 09:30:53 AM »
Mobile 1 is just as good and less expensive.
  • Male Posts: 5,058
« Reply #7 on: Apr 21, 2018, 11:13:53 AM »
For lubrication purposes, yes, but Redline is GL-4 instead of GL-5 (that is GL-4 compatible) and works much better with the transmission syncros. You can feel the difference.
  • Turtle Points: 26739
  • Male Posts: 3,522
  • Member since Dec '10
« Reply #8 on: Apr 21, 2018, 12:31:58 PM »
I run mt90 in trans, 80/90 in cases and diffs, I drain and put new in every 2 years. I'm running MC eco seal at trans output.
  • Male Posts: 4,256
« Reply #9 on: Apr 21, 2018, 08:27:08 PM »
As I remember, when I spoke to a Redline tech rep, they recommended MTL for my W56 transmission.  It made a very noticeable difference in shifting.
This time I tried Mobil 1 75W-90 Synthetic.  I noticed a much smoother shift and quick gear mesh than the non-synthetic I had in before.  I can't effectively compare the two (MTL vs Mobil 1).  Since my high ambient temperatures here in AZ can get up to 100+ degrees for 3 to 4 months, I decided to try the Mobil 1 75W-90.  For a W56 transmission, my 1986 Toyota Repair Manual says:  Oil Grade:  API GL-4 or GL-5, Viscosity: SAE 75-90 or 80W-90.
I would bet that Mobil Oil is aware of any issues with "yellow metal" and synchro gear corrosion, and have formulated their gear oil to meet the required synchro lock up on the shaft during shifts.  The brand of synchros is probably more important for proper synchronizing than the gear oil.  My transmission shop here said they only install Toyota factory synchros in these transmissions because the alloy is the best for proper synchronization.
I believe I could not tell the difference between Redline and Mobil 1 in my transmission as far as shifting.
Redline is an excellent choice, but at the time I was adding gear lube, it was way more difficult to source.  Difference in price for 7 quarts was about $50, so Mobil 1 was a little more economical and budget friendly at the time.
« Last Edit: Apr 22, 2018, 04:40:39 AM by Gnarly4X »
:)bestgen4runner
  • Turtle Points: 2120
  • Male Posts: 1,796
  • Member since Mar '16
« Reply #10 on: Apr 21, 2018, 09:33:07 PM »
I 100% concur
I am 1/5th of Perfect Fit
  • Turtle Points: 452
  • Male Posts: 3,554
  • I'LL NEVER MAKE IT...
« Reply #11 on: Apr 23, 2018, 09:05:29 AM »
I tried the sta-lube GL 4 and it shifted better than the GL 5 too.
T-Revv
  • Turtle Points: 722
  • Male Posts: 280
  • Member since Apr '17
  • Crawlin at work, Crawlin on the trails. best life.
« Reply #12 on: Apr 23, 2018, 11:57:36 AM »
Redline is great product.  We use MT-90 in the transmissions and Tcases here at Marlin.   Redline also makes this super cool product called shockproof, which is a multi viscosity.  Shockproof is cool for the diffs, but I think its a little too sticky and gums up transmissions and tcases.  Mobil one I know makes some good products too, but im just not familiar with them, and haven't ran them personally.
"I dunno I just woke up from a lil nap, it's a lil dark but you guys silly? I'm still gonna send it."
:)bestgen4runner
  • Male Posts: 1,796
« Reply #13 on: Apr 23, 2018, 12:26:14 PM »
I use Shockproof in the front and rear diff. Best diff oil money can buy.
mudmaster
  • Turtle Points: 3715
  • Male Posts: 2,854
« Reply #14 on: Apr 23, 2018, 12:33:37 PM »
Heavy or lightweight?
Time to go wheelin!
:)bestgen4runner
  • Male Posts: 1,796
« Reply #15 on: Apr 23, 2018, 12:53:12 PM »
I have always used the Pink/Red heavy stuff. It's $$$$$$ but Hard to beat it.
I like other people strain it when I drain it, then put it right back in and top off with new.
From RedLine
•Film thickness greater than an SAE 75W250, yet low fluid friction like 75W90
•Many performance racing applications like Sprint/Midget/Dirt Late Model Differentials, Detroit Lockers and spools, NHRA Top Fuel and Funny Car rear ends
•Not recommended for most synchro applications due to the product's extreme slipperiness
  • Male Posts: 5,058
« Reply #16 on: Apr 23, 2018, 02:34:35 PM »
From RedLine
What do you notice in the diver seat?  You can feel a transmission feeling better, but can you honestly tell any difference with the diffs?  I ask because I doubt that our actual use would reduce the lifespan of a diff using conventional. I run blend I think.
Last post Jul 17, 2004, 09:58:25 AM
by burnyota
synthetic oils?
Last post May 02, 2005, 01:04:53 PM
by blackdiamond
Last post Jun 13, 2005, 10:10:13 PM
by guywithuglyyota
Last post Jul 04, 2009, 07:04:38 AM
by hotrod
Last post Aug 24, 2015, 09:50:50 AM
by bugman-74
