...1987 Toyota with the 22rte ...getting 6-10 mpg?
5. Someone is taking the gas at night.
Gnarls, that was a thing of beauty. Beer on me when ever we shall meet.Sent from my iPhone using Tapatalk
Trying to analyze gas mileage over the internet is like sniffing flowers through your butt.Gas mileage can be effected by many things driving style, engine tune and health, probably have the most likely effect.Climate and elevation ambient air temperature, relative humidity, and elevation can significantly affect MPG.You obviously do not understand how that engine works.The ECU and sensors have to function properly and the engine has to be highly tuned in order to get maximum gas mileage.Why would you expect to get good or even decent gas mileage when you have a huge exhaust leak and critical feedback sensors are not even hooked up!!How are you calculating the gas mileage?What is the elevation and route and miles used to calculate the MPG - flat land, up hill down hill, freeway, in town?What brand of gas are you buying? What is the octane rating?What oil viscosity are you running?Are you using any oil or gasoline additives?What gear ratio are the ring & pinions?What size tires are you running?Did you check the odometer calibration?How many miles on this engine?When was the last time this engine was tuned?When was the last time the valve lash was checked/adjusted?Have you ever done a compression check?What do the spark plugs look like?Driving your truck like you are on a limited tight budget and gas is $10 a gallon will improve your gas mileage.Gnarls.
I fixed everything besides the temp sensor and it is getting 13-14 mpg which I'm thinking is still bad. I'm right at sea level, the engine is rebuilt and has 160 compression in each cylinder, spark plugs look perfect, I'm running 31" tires with the stock drivetrain. I have never had the engine tuned, but I have the timing and valve lash spot on. I'm also using 10w30 oil. I'm hoping that hooking up the temp sensor will help my gas mileage. I looked for the wire the other day but I'm going to probably have to trace it from the ecu.
Which temperature sensor?Gnarls.
I'm at sea level. My 3rz gets 14.
OOOUCH! Gnarls.
The ECT sensor (engine coolant temperature) plays a big part in fuel economy. Now the ecu thinks the engine is much cooler than it is, so it is sending a lot more fuel than the engine needs, to compensate. With the sensor disconected, there is a pre-set value temperature sent to the ecu and it is usually as cold as the sensor can read (on some cars). I'd get that fixed asap because it can also be bad for your piston rings, as the engine sends more fuel, it can contaminate or wash the oil on your piston walls which causes more friction. The correct spark plugs, gap and timing also plays a big part in performance and fuel economy.
The temp sensor that tells the ecu when it's warmed up, without it I think it's squirting out of the cold start injector the whole time?
This thread is kind of a train wreck.
This is what happens. You guys are testing the limits and bounds. Let's just stick to carburetors where it's safe?
The Cold Start Timer Switch operates the CS injector, not the coolant temp sensor.
The coolant temp sensor tells the ecu when the engine is at operating temp, w/it unplugged, the ecu will stay in "warm-up" mode ignoring all other sensors, when the one failed in my 3.0 last year, it got about 8-10mpg's.
Started by Mr_Cheese Toyota Pickup/4Runner Tech 1979-95
Started by mcg_916 Toyota Pickup/4Runner Tech 1979-95
Started by Yota Up Toyota Pickup/4Runner Tech 1979-95
Started by Mega Baby Huey Toyota Pickup/4Runner Tech 1979-95
Started by defrag4 Toyota Pickup/4Runner Tech 1979-95
