Author Topic: '96 4runner 3rd member dirrect swap in my 1980 pickup axle?  (Read 1121 times)
ADVLion
  • Turtle Points: 60
  • Male Posts: 27
  • Member since Oct '16
  • the dude yota's
I found a spare set of axles to rebuild and weld all the fancy gussets and rock protection on which came with a auto-locking 4.11 in the rear, and no 3rd member up front. I currently have 3.9 gears and I'm about to do a moderate lift on 31" tires. It seems like the 4.11s will be a nice upgrade as well. I found a 3rd member for sale locally from a 4runner, the ad says 96-2001 when I asked 4cyl or V6 he just replied "should be the same"...  :headshake: I know they're interchangeable but different... I searched the forum and it seems this will bolt up to my '81 axle BUT... will my axle shafts work? will my drive shaft bolt up? is this a direct swap or will I need to order a parts kit and plan on a rebuild?
redneckcustoms13
  • Turtle Points: 6720
  • Male Posts: 2,422
  • Member since May '15
4runner 95-02 yes it is an 8", yes it will go in any 79-95 pickup housing that was an 8"(not a 7.5 2wd), and lastly your 81 rear axle is a narow track. If you use uour 81 housing with the 4runner diff you will need to use your axle shafts as well. 86-95 rear axle is 3" wider and have shafts that are 1.5" longer on each side. The 95.5 up 4 runner is 3 "wider that that so 6" wider than the 81.
01 double cab hunting truck
06 tacoma street truck
ADVLion [OP]
  • Turtle Points: 60
  • Male Posts: 27
  • the dude yota's
ok great, the axle shafts are still 30 spline. Good info, thanks Redneck! That means it'll work on the front too, except the flange which could be one of two Toyota bolt patterns I've learned from the forum.
ADVLion [OP]
  • Turtle Points: 60
  • Male Posts: 27
  • the dude yota's
Another snag, I'm starting in on the axle rebuild, I welded the gussets about six months ago now. I go to install new races in the knuckles tonight and they're about a 1/16" taller.... this is the marlin MCAX-1511 service kit, did I order the wrong kit? is this an upgrade?
OVRAROK
  • Online The 2.5K Group
  • Turtle Points: 22541
  • Male Posts: 2,745
  • Member since Dec '10
have you confirmed that they are ALL the way down
ADVLion [OP]
  • Turtle Points: 60
  • Male Posts: 27
  • the dude yota's
yes, I did a side by side comparison outside of the axle after I saw that the first one I installed was protruding more then the original.
OVRAROK
  • Male Posts: 2,745
I would call them, best time is right when they open, I'm sure they will straighten it out for you
ADVLion [OP]
  • Turtle Points: 60
  • Male Posts: 27
  • the dude yota's
so then probably not an upgrade... whats another week or two? :hammerhead:
Thank you OVRAROK! I would have just kept searching and searching the forums
redneckcustoms13
  • Male Posts: 2,422
I've had that on new koyo knuckle bearings. As long as the knuckle still goes on and it isn't too tight on the resistance when turning let it eat.
ADVLion [OP]
  • Turtle Points: 60
  • Male Posts: 27
  • the dude yota's
Thanks Redneck! that's spot on, I gave the Marlin team a call a was assured that if the race goes in.... its the right bearing, just a new angle. I did check and the knuckle still goes on easy, just wasn't sure how it would work out with the shims and freaked out. Thanks guys!
Last post Oct 31, 2009, 06:43:38 PM
by 93hunter
Last post Oct 12, 2010, 10:58:59 PM
by THK Matt
Last post Sep 10, 2013, 05:38:25 PM
by Goose0850
Last post Mar 04, 2014, 01:08:21 PM
by havik
Last post Sep 25, 2016, 07:19:16 PM
by john90lux
