Author Topic: Expedition Build -duals, or is a 4.7 gearset in the case ok?  (Read 2991 times)
flhtom
  • Male Posts: 21
  • Member since Jun '13
So here's my plan; if it's stupid just say so! I want to run my little 31" AT tires as a DD, but for off-road, i will install 36" TSR's. Question is, will the crawl ratio with a 4.7 transfer case be sufficient for general exploring out here in the desert (don't plan on running John Bull or technical trails), just stuff like Bradshaw Trail, Fish Creek Canyon and general trail riding. According to the chart, the 4.7's will give the 36" tires about the same crawl ratio as the stock 2.8 with 31" tires. So, i could then have the best of both worlds (75 on the freeway, and still workable off-road). It is a lot of work to change the wheels out, but i don't wheel very often. I suppose if i ran 5.29's, duals and also 4.7's in addition to the 2.8 stocker, i could just run the 36's all the time, but gas mileage would be worse, right? Thanks for input/ideas. -tom
84 4Runner 63's RUFs 36" TSLs 5.29 Frt Aussie
300m Birfs and Hub Gears Full Detroit Rear
V-Man
  • Turtle Points: 29
  • Male Posts: 792
  • Member since Sep '04
When you change to larger tires, you change the ratio in your rear end and Front diffs. It keeps your Speedo and fuel correct.  Most overland( that is what I think you mean by "Expedition". ) vehicles run about a 33' tire.
Use the calculator and find the right tire size, and pinion ratio .
Snowtoy
  • Turtle Points: 1403
  • Male Posts: 2,583
  • Member since Sep '03
The purpose of running dual cases or a single case w/4.7's is to actually reduce your crawl speed, allowing you to idle over obstacles, up onto/off of ledges, etc., reducing your risk of damage, not as a replacement for correct diff gear/tire sizes.
Based on what your needs of a DD/expedition rig and where you will be wheeling it, I would run 33 AT's, good highway mpg's and work well enough off road, and w/4.88 gears, you would have stock mpg/performance.  I would then run dual cases with either stock 2.28's, or 2.28 and 4.70, I currently run dual 2.28's, and usually find myself needing a little lower gearing from time to time.
T-Revv
  • Turtle Points: 722
  • Male Posts: 278
  • Member since Apr '17
  • Crawlin at work, Crawlin on the trails. best life.
The reason dual cases is great is the options it gives you.  You want the slow and control that comes with lower gears like snowtoy said, but often when people run a single 4.7 case they find the gap between high range and low range to be too much.  High range is too high and low range is too low for most obstacles.  With a the dual case, you maintain that factory low range to help bridge that gap for easy trails. Like Snowtoy said the best way to go is a "Dual Ulitmate Case" (2.28 front case, 4.7 rear case).  Marlin calls this the ultimate because it really is.  You maintain your factory low, you have the 4.7 for harder areas, and double low for when you really need to get technical.  Overlanding/ Expedition is going to put all kinds of scenerios in front of you, and having the dual ultimate, you will never be wishing you had a different ratio, because all the options are right there.
"I dunno I just woke up from a lil nap, it's a lil dark but you guys silly? I'm still gonna send it."
Axlesnap
  • Member since Mar '11
Although new to the toy scene, I DD my 1st gen runner, 5:29's 35 inch tires(MT) bumpers winch, full cage and getting about 17 MPG with a stock 22RE with cold air intake, performance muffler(no cat)
flhtom [OP]
  • Male Posts: 21
17 mpg is pretty good, for running bigger tires; i get about 15, on a good day, with the little skinny 31" BFG A/Ts. So, i think the 4.70s in orig. transfer case and original rearend ration(4.10) will allow me to run the 36" TSLs offroad, and still run the skinny tires for best daily driver mileage, plus; it will still be able to commute at 70 mph. i do see dual cases in my future, 'tho! when i dual case it, i will install the 5.29s (no more 31" tires). Thanks for replies, guys.
blackdiamond
  • Turtle Points: 1174
  • Male Posts: 5,052
  • Member since Dec '03
  • Crawlin with Marlin
The issue will be getting to the trail with 4.10s and 36” tires. I gave up on 4.10 gearing in my ‘85 when I went to 33” tires.
4.88 gears with 33” tires is a great overall solution. Get the BFG 33x9.50 if you want a skinny.
300k
  • Turtle Points: 3744
  • Male Posts: 623
  • Member since Jun '15
  • GREEN NAME MAN BAD!
    • Please ban me!
          OK!
      I am banned!
I agree with BD. if you or someone you know can set up a 3rd member, ditch the 4.10s and look into 4.88 gears.
Yotadekime
  • Turtle Points: 17
  • Member since Aug '18
  • Danger first
I would go with the consensus and regear for 33s first. Duals are a great extra tool to use in a rig, but my opinion is unless your rig lives in the rocks I would regear first.
Naturally a realist, preferably an optimist.
Last post Aug 22, 2005, 11:51:13 AM
by MiniSimp
Last post Oct 19, 2008, 08:13:20 PM
by Duffil
Last post Jul 18, 2009, 01:39:19 PM
by ia yota
Last post Feb 12, 2013, 10:52:02 PM
by 95Toyota
Last post Oct 23, 2017, 07:37:29 AM
by H8PVMNT
