Author Topic: ECT removal after auto/manual swap?  (Read 1647 times)
58rennur4
  • Turtle Points: 204
  • Male Posts: 39
  • Member since Aug '17
  • WHAT?
« on: Aug 17, 2017, 04:31:35 AM »
So about the automatic ECT transmission control box forward the auto shift levers, does this need to stay in for any reason after a manual swap?
I am not sure after looking around other threads (or trying to understand the schematic) if the ECT ( Auto Transmission Control Box) is even necessary to jump the neutral wires, attach the reverse lights, or the 4wd indicator light. Or if these functions run directly through the main ECU directly.
Thanks..
R.DesJardin
  • Turtle Points: 680
  • Male Posts: 489
  • Member since Mar '08
    • RADesigns Products LLC
Re: ECT removal after auto/manual swap?
« Reply #1 on: Aug 21, 2017, 11:49:49 AM »
Only needed after you burn up the clutch and continue to kill the engine trying to get up a hill and then you realize the auto was easier to wheel and you want to put it back in.  :greengrin: One foot on the brake and one on the gas. Sorry had to.....
R.DesJardin
cporche
  • Turtle Points: 306
  • Member since Feb '17
« Reply #2 on: Aug 21, 2017, 12:44:28 PM »
nope you can ditch it completely.
you will jump the start circuit below the intake where the trans wire harness came to. your 4wd and reverse lights will also tap into the same area different plugs however. i cut the wires of of the old trans and used them to wire in the switches so it retained some of the oem look.... if you need help finding out what pins and such i can send you pictures of what i did.
redneckcustoms13
  • Turtle Points: 7674
  • Male Posts: 2,513
  • Member since May '15
« Reply #3 on: Aug 23, 2017, 07:09:18 AM »
That is why this forum is useful for so many people. Thank you for your valuable input cporche.
01 double cab hunting truck
06 tacoma street truck
Burl
  • Turtle Points: 271
  • Male Posts: 389
  • Member since Jan '07
  • Wannabe Smokejumper
Burl
  • Male Posts: 389
« Reply #5 on: Aug 23, 2017, 03:47:32 PM »
58rennur4 [OP]
  • Male Posts: 39
  • WHAT?
« Reply #6 on: Aug 28, 2017, 10:04:24 AM »
Post number 9 shows the jump next to the oil filter.
Thanks for this and all other comments..
Last post Jun 09, 2004, 09:45:31 AM
by kyle_22r
Last post Aug 18, 2004, 08:43:47 PM
by tbam
Last post Nov 05, 2009, 07:25:43 AM
by -Jake-
Last post Dec 01, 2009, 07:22:11 AM
by 854RUN
Last post Aug 13, 2015, 07:00:29 PM
by R.DesJardin
