Author Topic: Driveline lash/ axle wrap?  (Read 5209 times)
1980firstgen20r
  • Male Posts: 41
  • Member since Apr '17
  • 1st gen is better
« on: Aug 08, 2017, 08:36:51 AM »
Ok guys If you've seen my other posts of chasing the noise/ vibration I hear and feel while in 2WD, if you haven't seen my other posts take a gander through this fourum category and check them out
I've made a short video of what I'm hearing
https://m.youtube.com/watch?v=t0MSQF3Npcg
Roll with the Coaliton crawlers
Mountain Mafia
  • Turtle Points: 26739
  • Male Posts: 3,523
  • Member since Dec '10
Re: Driveline lash/ axle wrap?
« Reply #1 on: Aug 08, 2017, 08:43:16 AM »
Do you have c.v. at t case?
Also what is the driveline angle compared to the rear pinion angle.
1980firstgen20r [OP]
  • Male Posts: 41
  • 1st gen is better
« Reply #2 on: Aug 08, 2017, 09:00:03 AM »
No cv, standard two u joint shaft
12* angle on the shaft itself
76* at the pinion
90* at the Tcase
So that's 14* out of parallel? Right?
And yeah I know that's really bad
Mountain Mafia
  • Male Posts: 3,523
« Reply #3 on: Aug 08, 2017, 10:00:43 AM »
76* at the pinion
90* at the Tcase
If your driveline angle is 12° degrees, your pinion in rear should be at 10°, that 2° pointed toward the ground, allowing for axle wrap
  • 96ZJ v8
  • Turtle Points: -415
  • Male Posts: 4,823
    • Buy me a drink
« Reply #4 on: Aug 08, 2017, 10:30:12 AM »
im struggling to comprehend how 90* can be the number at the TCase. 90* is a right angle.
  • Male Posts: 41
  • 1st gen is better
« Reply #5 on: Aug 08, 2017, 12:35:35 PM »
That's exactly the angle could be different on flat ground. But what you need is the diffence between the two angles
I'll post pics of it when I get home after work today if that helps you "comprehend"
Mountain Mafia
  • Male Posts: 41
  • 1st gen is better
« Reply #6 on: Aug 08, 2017, 02:46:58 PM »
Also the tranny/ transfer case is a w56 single case. I swapped out the L43 and installed a bud built crossmember to accommodate the w56. I hope that helps you comprehend.
1980 20r long bed.
Mountain Mafia
  • Male Posts: 3,523
  • 96ZJ v8
  • Male Posts: 4,823
    • Buy me a drink
« Reply #8 on: Aug 08, 2017, 04:31:34 PM »
90* is like an L. Pictures would help.
:worthless:
  • Male Posts: 41
  • 1st gen is better
« Reply #9 on: Aug 08, 2017, 04:59:20 PM »
:worthless:
Ohhh you just wait. I know what a right angle is.. i was baffled my self when I checked the angle, give me a few hours to get home and I'll show you
Mountain Mafia
  • Male Posts: 41
  • 1st gen is better
Mountain Mafia
  • Male Posts: 3,523
« Reply #11 on: Aug 09, 2017, 11:51:50 AM »
 :popcorn:
  • Online Gold Turtle Award
  • Turtle Points: 5134
  • Male Posts: 4,274
  • Member since Jun '16
  • 4-wheeling vicariously.
« Reply #12 on: Aug 09, 2017, 06:47:00 PM »
Trying to analyze vibrations over the internet is like sniffing flowers through your butt.  :gap:
BUTT.... there are some diagnostic things we can do to help discover where the vibes are coming from.  :thumbs:
There's quite a bit of "stuff" on this..  :biggthumpup:
Here's a good one....   http://www.hotrodhotline.com/md/html/drive_shaft_harmonics.php
Gnarls.  :smokin:
  • Male Posts: 41
  • 1st gen is better
« Reply #13 on: Aug 10, 2017, 04:50:38 PM »
:worthless:
Ok guy'a finally had time to get these pics up
http://m.imgur.com/a/XPidP
I did move to a more level'd surface and got different measurements but close to the ones before
Rear drive shaft angle reading @ 16*
Rear pinion angle reading @ 76*
T case angle reading @ 86*
Give me some feed back.
Also I've been trying to diagnose this for a while, I plan on installing chevy 63's in the rear and I know because of the longer shackles my pinion angle will slightly change but since I took the video of what's going on in the rear end it's got me thinking y'all might have some more input about what I can do
Mountain Mafia
  • Male Posts: 4,274
« Reply #14 on: Aug 11, 2017, 03:14:00 AM »
1980firstgen20r,
What do you think is causing your vibrations?
When do you feel the vibrations?
If the vibrations are caused by out of phase U-joints or driveline angles, it’s usually a fairly straight forward fix.
If the vibrations are caused by bad U-joints, or pinion bearings, they usually can be detected by checking for excessive movement.
Some axle wrap is normal.  Excessive axle wrap may occur  on heavy acceleration, braking, and on the trail while applying lots of throttle torque, like rock crawling.
https://www.drivelinesnw.com/part-trouble-shooting/vibration-analysis/angle-analysis/measuring-and-correcting-angle-problems/
https://www.4wd.com/p/pro-comp-degree-shim-99-200/_/R-DFCW-99-200?utm_source=google&utm_medium=cpc&utm_campaign=shopping&emlprox=out&ppcfon=1&gp=1&scid=scplpEXP99-200&sc_intid=EXP99-200&gclid=EAIaIQobChMInefJv_rO1QIVgYl-Ch18MgRZEAQYBCABEgLnsPD_BwE
Gnarls.  :inthedark:
« Last Edit: Aug 11, 2017, 03:20:36 AM by Gnarly4X »
  • 96ZJ v8
  • Male Posts: 4,823
    • Buy me a drink
« Reply #15 on: Aug 11, 2017, 10:22:18 AM »
tcase 4*, rear pinion 14*,
  • Male Posts: 41
  • 1st gen is better
« Reply #16 on: Aug 11, 2017, 10:29:08 AM »
Am I reading the angle finder wrong or something?
Mountain Mafia
  • 96ZJ v8
  • Male Posts: 4,823
    • Buy me a drink
« Reply #17 on: Aug 11, 2017, 11:41:04 AM »
yes
  • Male Posts: 41
  • 1st gen is better
« Reply #18 on: Aug 11, 2017, 12:25:50 PM »
yes
The how should I read it, I don't understand. Would appreciate it if you could explain it and not be so short...
Mountain Mafia
  • Male Posts: 41
  • 1st gen is better
« Reply #19 on: Aug 11, 2017, 12:34:29 PM »
1980firstgen20r,
Gnarls.  :inthedark:
I believe what's causing the vibration/ gear grinding noise is the drive shaft being out of parallel. The u joints are brand new. Had the guy at the drive shaft shop replace them when I had him shorten down the shaft to accommodate the w56. And the vibration/ noise happens when I'm in 2WD driving on the pavement. In 4WD the noise isn't bad at all.
I also Checked the play on the ring and pinion when the original axle was in the truck and it seemed fucked up to much play. So I installed a 2nd generation axle that I had already taken apart and rebuilt. So I trust the axle/ ring and pinion. What I don't trust is the rear drive shaft angle being out of parallel. I don't know if I need to point my pinion up or down to make it match the T case angle. I have a few other threads in this category with some more info if your interested in reading them. Getting tired of posting the same thing over and over
Mountain Mafia
Last post Aug 18, 2004, 11:06:30 AM
by WHITE_TRASH
Last post Sep 30, 2004, 04:11:04 PM
by brainlessfool
Last post Mar 03, 2005, 01:17:40 AM
by mr4x42u
Last post Oct 17, 2008, 12:54:35 PM
by COToy91
Last post Mar 16, 2011, 10:21:23 AM
by 83 Crawler
