Author Topic: LCE distributor worth it?  (Read 2842 times)
MrFatEggs
  • Member since Apr '17
« on: Jun 02, 2017, 11:09:24 PM »
I am almost done with my hybrid build, but don't have a distributor or oil pump. Is it worth it to buy the $260 lc engineering distributor vs the $70 eBay generic One? Also is the lc engineering $100 oil pump worth the extra money vs the $15 eBay ones?
  • Turtle Points: 7571
  • Male Posts: 3,561
    • emsvitil's album
Re: LCE distributor worth it?
« Reply #1 on: Jun 02, 2017, 11:38:23 PM »
no, no, no and no
Try rockauto.     You could get the pump locally, but since you're waiting anyway...................
  • Turtle Points: 452
  • Male Posts: 3,554
  • I'LL NEVER MAKE IT...
« Reply #2 on: Jun 05, 2017, 09:14:39 AM »
I would rather scrounge a used stock distributor.  I had one of the cheap re-maned ones seize up and blow the teeth of my distributor drive gear.
SlayTank
  • Turtle Points: 234
  • Member since Apr '15
« Reply #3 on: Aug 15, 2017, 08:50:49 PM »
I was looking at distributors as mine needs a new VAC advance. The VAC advance was almost as much as a entire rebuilt distributor off rock auto. then I saw the DUI distributors that LCE sells. Im not drag racing but if I'm going to pay 200$ for a new distributor might as well pay a little extra and get the DUI. Not so much for performance but because it simplifies the entire ignition system and parts would be easy to find (just replace with a std GM HEI)
What do you guys think? I looked around and didnt find any reviews on them
pleasetellmeno
  • Turtle Points: 507
  • Member since Sep '16
    • Buy me a drink
« Reply #4 on: Aug 15, 2017, 09:13:36 PM »
I tried a Cardone distributor off rock auto, had the vacuum advance go out pretty fast. I warrantied it, and the new one went out in 2 days. ended up just buying the vacuum advance diaphragm off LCE. Rock auto gave me my money back.
  • Turtle Points: 5134
  • Male Posts: 4,271
  • Member since Jun '16
  • 4-wheeling vicariously.
« Reply #5 on: Aug 16, 2017, 04:46:24 AM »
I would go oem on both
Those 2 parts are obviously important.  I’d have trouble justifying the cost of the LC product, although they are most likely very high quality.  I would tend to stay away from the Autozone stuff and remanufactured parts, especially for the disty – mainly for the advance curve specs.
I’d tend to stick with OEM, it’s a safe choice.
Be careful whenever you read or hear someone say “OE”.
The acronyms OE and OEM are often tossed around together.  OE, in many circles, means Original Equivalent.  OEM means Original Equipment Manufacturer.  There can be a big difference!  OEM typically means the part is manufactured by the same “original” manufacturer, and source, so it meets the same exact specs.
OE can also mean Original Equipment.  Meaning that the part is the exact same part, made by the same source, that came on the original vehicle at the time of manufacturing.  If you go to your local car dealership and have them install a new windshield, they will only install OE (Original Equipment - if its still available), same as what the vehicle came with from the factory.
OE can also mean Original EQUIVALENT and does NOT mean it was manufactured by the same manufacturer, source, or meets the same exact specifications as the OEM or Original Equipment.
The other term, of course, is “aftermarket” - that typically has nothing to do with the manufacturing source of Original Equipment or Original Equipment Manufacturer.
« Last Edit: Aug 16, 2017, 04:54:49 AM by Gnarly4X »
Last post Oct 05, 2004, 05:45:19 PM
by burl4x4
Last post Dec 04, 2006, 06:27:29 PM
by DeMented Toys
Last post Nov 30, 2006, 11:31:35 AM
by badwheelr
Last post Mar 22, 2007, 12:06:33 AM
by kneedownnate
Last post Nov 14, 2007, 11:43:43 AM
by 79coyotefrg
