Picked up some reading material. I love the classics...
Change you change the equivalent of the power valve spring on a weber?
Man I don't know. I would certainly richen the mains. You can't stay that lean or you will smoke something. If you have a section of air correctors you could put some smaller ones on to richen a bit at highway rpms. Have you tried one step richer idle jets? I am finding they do a lot at cruising speed.On the pig rich: At WOT at lower rpm you have very little vac for a second when you floor it, so you aren't pulling much from the mains at all, but your accelerator pump if dumping a shot of fuel in there to compensate. So it should get really rich for a second... But in your case does it snap out of it as rpms increase or is it just really rich all the time?I have the progressive version so I don't know, but it seems like the 38 synchronous would dump a whole lot all at once when you stomp on it. When you ease into the throttle will it stay leaner?I guess I don't have a solution, I'm still trying to understand myself. I think you are on the right track with the emulsion tubes. I think you should mess with richer (smaller) air correctors too.When I get my AF gauge hooked up I will let you know what mine looks like.
Hey Gillesdetrail,The last spec sheet on the 38 that I have is...45 idle jets - Stock setting: 45125 mains - Stock setting; 1.85160 air correctors - Stock setting: 1.8518mm float height 2mm needle travel Stock setting: .40, Stock: 22.5 psi Recommended? 3 to 4 psi?Emulsion tube? Stock setting: F50weber 38What have you experienced or tested to change the stock specs?What are your engine specs?Intake manifold?Exhaust system?Cam profile?Your fuel filter is fresh?Is the fuel pump stock?Is the fuel pressure regulated?Have you tried increasing the fuel pressure?What is your elevation?What octane fuel are you running?What air filter do you have on the carb?Have you tried testing without the air filter installed?Just curious? It sounds like its running out of fuel? float level? fuel pressure? possible vacuum leak?18 AFR is getting close to dangerously lean.Gnarls
So I spent some time tuning today....The lean hesitation is gone and cruising speed is between 15-16:1 afr.
Could the 9.0:1 be due to much accelerator pump ??
It is true I may be over analyzing, the general concensus is don't tune acording to what the a/f meter tells you, tune according to what the engine likes.
For example, it idles best with an a/f reading of around 12.5 on idle, which seems way to rich, but that where the engine likes it.
I eased onto the throttle and it stayed below 9.0 for about 5 seconds until I reach 4k
I don't know if I'll ever be able to tune this out
I just don't want to wash the cylinders of oil and cause excessive wear.
That sounds like reversion or fuel standoff........https://www.youtube.com/watch?v=zs8mnaouP8U
... I'm also starting to think it is more of a mixture conditioning issue. Maybe not enough booster signal because of the small cam. Reversion seems to be more of an issue with cams that have a lot of overlap.
Maybe I missed is, but have you checked the power valve?
Nope! I had no idea of it's function, but after reading about it, I may cancel it and tune accordingly and it may help!
Gnarly: I do have an adjustable cam gear, advancing it any amount helps with bottom end and midrange but kills top end and the truck is slower overall. Checked the plugs for detonation, colour is allright. I already run the lash on the tight side, I don't think it will really make a difference.
Supposedly ......??
Started by H8PVMNT « 1 2 3 4 » Project Research and Build-Ups
Started by Cheesemaker Chit Chat Camp
Started by knucklebuster Parts For Sale
Started by H8PVMNT « 1 2 » Chit Chat Camp
Started by H8PVMNT « 1 2 3 » Chit Chat Camp
