I ordered a set of sealed throttle shaft bearings from Pegasus Racing but have yet to get around to installing them.
And then I'll do a V6 swap... LOL.
Best I got with my weber was 19 mpg, kicking, bucking and gutless the whole way. Soon as I got back from passing smog it changed to 14-15 mpg with good power and better driveability. Still never did well at angles, even with the high angle mod.
I am guessing this is all the better I am going to get. I have kept edging into leaner with the secondary. I have found the point at which I have what I think is the my safest jet on the lean end, but better power is had one step fatter. At this point I have the primary on the leaner side and the secondary right in the middle. Until I get an AF gauge I think I am done.I was wheeling up steep coulees and off camber notches yesterday when we were hunting for our horses and it was flawless at all angles. Not even a hiccup. All I did was the standard hill climb mod and tweaking the float level a bit. I guess the regulator probably helps. I settled in at about 2.8 psi on the pressure gauge.
What did Pegasus say about the leaking shafts?
What V-6 would you swap?Gnarls.
Well, I didn't actually speak to anyone there. Their catalog offers these sealed bearings as a solution for throttle shaft leaks, it sounded like a good idea, it's not terribly expensive, so I bought them. I'll document the install and results whenever I get around to it.Chevy 4.3. Simple, cheap, reliable, LOTS of torque for towing. I just recently missed a complete 2000 year engine and trans with under 100k miles for $500. I'd sell the trans (4L60E, I think) for a $100 and be on my way. Note that I will ditch all electronics and convert to carb and HEI distributor for simplicity's sake and because I'm basically a caveman.
Awesome! I want your comments on that book and if you think it is worth the purchase for our downdrafts, thanks for the info!
Interesting....Wow.... Chevy 4.3. Of course it means abandoning the Toyota badge..... BUT... I would REALLY love to swap in a V-8! Historically, I was a long time Chevy addict.... 2 Chevy Malibus, 2 Chevy Corvettes, 1 Chevy pickup, 1 Chevy Caprice Classic - all V-8s.Gnarls.
Well, sort of. It's still a Toyota truck and I plan to retain a Toyota 5-speed. I'd love to do a 5VZ-FE but that's a lot more money and involves computers and such.I've heard of people doing the V8 swaps and these days and aluminum LS would be the hot ticket but even an old school smallblock is just such total overkill plus the packaging would be more difficult. The 4.3 will put out somewhere between 250-280 ft-lbs which is more than enough. My buddy has a 2000 Astro and it has no problem at all hauling three of us, all of our camping gear, three dogs and a couple motorcycles in a trailer out back. I'm sure my truck is lighter than that van.
I got it on sale for $12, it's well worth that much. As stated elsewhere It does cover all the Webers which is a bit superfluous for most of us running DG*V carbs, but between the interesting history and the baseline jetting charts in the back, I think it's worth having around. It does have a good section on a DGEV rebuild. It goes on and on about how the Weber carbs can be tuned for economy or performance, and kind of both on the progressives, which seems to be true as I mess with mine.What you get out of it though is the design and theory is the same regardless of which Weber. What you have is versatility since you can tune every aspect so very much.It does help get your head wrapped around emulsion tubes...
Thanks! Cheapest I found was 35$cad, I think I'll buy it just for the emulsion tube part. I got my 125 and 130 mains and 150 and 160 airs in the mail, I hope to run it soon!
Hey you clowns quit stinkin' up my Weber thread with chevy talk!
I think it's going to be the secondary main jet change that gets you right at WOT/mid. Be sure and let us know!
H8'erDoes that book have anything to say about the secondary idle jet? I cannot for the life of me understand what that's supposed to do or how it affects things...
I haven't got that far into the book yet. I have messed around with it though and based on the changes and reading a few things I believe on the progressive carbs it is kind of a transition piece. Like when you just step into the secondary and maybe 10% into it, this is your fuel. So if it's lean you should have a flat dip when you hit the secondary until the secondary main kicks in. On the flip side I richened the secondary main a step and found that the secondary hits a little harder and you get a more audible pull when they engage.I had it 2 steps richer and I lost a little economy, so I think we spend a lot of highway time just tipping into the secondary and using this jet when we buck a head wind or pull a slight grade.Anyway if I find anything different I'll post it up but that's what I have experienced tuning so far.
... I think I have found a really good happy place as I am getting better fuel economy while at the same time having more power.
Have you ever thought of going with a diesel?
Time to call BS on my tune... AEM wideband AF gauge is on the way.
Started by H8PVMNT « 1 2 3 4 » Project Research and Build-Ups
Started by Cheesemaker Chit Chat Camp
Started by knucklebuster Parts For Sale
Started by H8PVMNT « 1 2 » Chit Chat Camp
Started by H8PVMNT « 1 2 3 » Chit Chat Camp
