Author Topic: 87' single cab build.  (Read 8416 times)
82.1st.gen
  • Turtle Points: 37
  • Male Posts: 52
  • Member since Jul '08
« on: Jun 02, 2017, 08:18:42 AM »
In parts gathering mode:
The truck has a Dana 60 center and Toyota outers under it now . I won't be running that but I will take out the trunion eliminators, and 6 stud knuckles and I'll end up running a toy axle up front no hyrbrid crap.
I've got rcv 300m shafts
The rear is a narrowed Dana 60 4.88 gears and Detroit locker
It is already 3.4 swapped needs some motor work but it's getting close! Here is the truck the way it sits
1992 Toyota 4x4 sr5 auto/3.0 swapped to r150f 5 speed and 3.0 swapped for 02 3.4!
redneckcustoms13
  • Turtle Points: 7674
  • Male Posts: 2,513
  • Member since May '15
Re: 87' single cab build.
« Reply #1 on: Jun 02, 2017, 08:39:06 AM »
Nothing wrong with the 60s. Quite a bit stronger than the toyotas. Is there a reason you would rather go with toyota?
01 double cab hunting truck
06 tacoma street truck
82.1st.gen [OP]
  • Turtle Points: 37
  • Male Posts: 52
« Reply #2 on: Jun 02, 2017, 08:41:45 AM »
Having to run custom splined axles seems like a pain.
82.1st.gen [OP]
  • Turtle Points: 37
  • Male Posts: 52
« Reply #3 on: Jun 02, 2017, 08:43:44 AM »
And I really don't wanna grind on a set of rcvs
redneckcustoms13
  • Male Posts: 2,513
« Reply #4 on: Jun 02, 2017, 09:37:41 AM »
Good enough reason I guess.
joeyf
  • Turtle Points: 848
  • Member since Dec '06
« Reply #5 on: Jun 02, 2017, 10:03:07 AM »
The front was definitely a waste of a 60 running toyota outers. Should stay with the rear 60 though,  that will outlast a toyota rear.
« Last Edit: Jun 02, 2017, 10:37:06 AM by joeyf »
82.1st.gen [OP]
  • Turtle Points: 37
  • Male Posts: 52
« Reply #6 on: Jun 02, 2017, 10:32:57 AM »
Just a rear 60 cut down with toy outers... if someone wanted to hassle with custom shafts and carry the spares it would be a pretty tough front end.
82.1st.gen [OP]
  • Turtle Points: 37
  • Male Posts: 52
« Reply #7 on: Jun 02, 2017, 05:18:27 PM »
The pain of drilling 256 holes my $0 Bead lock rings
82.1st.gen [OP]
  • Turtle Points: 37
  • Male Posts: 52
« Reply #8 on: Jun 07, 2017, 01:03:15 PM »
Housing I picked up to throw all my guts in. 6 stud hy steer, trunion elimination, rcv 300m shafts, and I'm on the hunt for 4.88 gears.
  • 96ZJ v8
  • Turtle Points: -415
  • Male Posts: 4,823
  • Member since Jun '07
    • Buy me a drink
« Reply #9 on: Jun 07, 2017, 03:44:16 PM »
:popcorn:
82.1st.gen [OP]
  • Turtle Points: 37
  • Male Posts: 52
« Reply #10 on: Jun 09, 2017, 03:42:04 PM »
Driveline tech front drive shaft
82.1st.gen [OP]
  • Turtle Points: 37
  • Male Posts: 52
« Reply #11 on: Jun 09, 2017, 03:47:55 PM »
Dana 60 Detroit locker with 5.13 gears... now I'm contemplating keeping the front toy/60 hybrid... thing is beefy and I'm pretty sure the Toyota 8" third will be the part that will constantly break!
Willard
  • Turtle Points: 1608
  • Male Posts: 627
  • Member since Dec '14
« Reply #12 on: Jun 09, 2017, 05:34:50 PM »
I would keep the current set up. You would be downgrading and you might kick yourself later for it.
82.1st.gen [OP]
  • Turtle Points: 37
  • Male Posts: 52
« Reply #13 on: Jun 09, 2017, 05:38:09 PM »
My thoughts exactly. I was also looking at foothill off-road and they make a drop in 35 spliNe alloy inner axle cut down for my rear toy/60 wich would work out perfect for the 35spline spool I've had sitting on my shelf for the last 2 years.
« Last Edit: Jun 09, 2017, 09:07:14 PM by 82.1st.gen »
Willard
  • Male Posts: 627
« Reply #14 on: Jun 09, 2017, 07:11:05 PM »
My thoughts exactly. I was also looking at foothill off-road and they make a drop in 35 spliNe alloy inner axle cut down for my rear toy/60 witch would work out perfect for the 35spline spool I've had sitting on my shelf for the last 2 years.
It was meant to be lol
redneckcustoms13
  • Male Posts: 2,513
« Reply #15 on: Jun 09, 2017, 08:26:54 PM »
Back to my first post in your thread lol I hope you keep em.
82.1st.gen [OP]
  • Turtle Points: 37
  • Male Posts: 52
« Reply #16 on: Jun 09, 2017, 08:44:58 PM »
I know... I know...  now I just need to pickup my install kit for my gears and I'll throw up some better pictures of the front end setup.
redneckcustoms13
  • Male Posts: 2,513
« Reply #17 on: Jun 12, 2017, 05:13:41 AM »
5.13s and a 3.4 :clap:
82.1st.gen [OP]
  • Turtle Points: 37
  • Male Posts: 52
« Reply #18 on: Oct 29, 2017, 02:12:30 PM »
Still need to pick up my install kits... haven't really touched the truck since hunting season started wich that turns directly into fishing season. But did get the heads swapped out and the motor back in running order going to be getting a new cross over put together
82.1st.gen [OP]
  • Turtle Points: 37
  • Male Posts: 52
« Reply #19 on: Oct 29, 2017, 02:14:32 PM »
My cousin had some 47" ltbs laying around and wanted to see what one looked like bolted up... tight fit for sure
82.1st.gen [OP]
  • Turtle Points: 37
  • Male Posts: 52
« Reply #20 on: Nov 11, 2017, 05:09:57 PM »
Ended up scoring a set of 14/42-15 iroks with bead locks and a 5th 39.5 with matching bead lock.
82.1st.gen [OP]
  • Turtle Points: 37
  • Male Posts: 52
« Reply #21 on: Nov 11, 2017, 05:12:15 PM »
Get to pick up my axle shafts Tuesday. Got the splines opened up to fit the 60 carrier. Now just trying to locate a cheap locker!
82.1st.gen [OP]
  • Turtle Points: 37
  • Male Posts: 52
« Reply #22 on: Nov 11, 2017, 05:21:07 PM »
Trial by fire.  Breaking the motor in.
https://youtu.be/9JMT3scap_E
redneckcustoms13
  • Male Posts: 2,513
« Reply #23 on: Nov 12, 2017, 11:09:20 AM »
Well that's one way to do it.
82.1st.gen [OP]
  • Turtle Points: 37
  • Male Posts: 52
« Reply #24 on: Nov 12, 2017, 02:14:40 PM »
Got the 42s on checking clearances and what need to be trimmed
82.1st.gen [OP]
  • Turtle Points: 37
  • Male Posts: 52
« Reply #25 on: Nov 12, 2017, 02:15:54 PM »
Firewall is golden just need to trim the front of the fender
82.1st.gen [OP]
  • Turtle Points: 37
  • Male Posts: 52
« Reply #26 on: Nov 12, 2017, 03:50:23 PM »
Trimmed the rear up
redneckcustoms13
  • Male Posts: 2,513
« Reply #27 on: Nov 12, 2017, 05:01:22 PM »
Looks like full lock full stuff is not going to clear that fire wall.
82.1st.gen [OP]
  • Turtle Points: 37
  • Male Posts: 52
« Reply #28 on: Nov 12, 2017, 06:20:04 PM »
Gotta get my bump stops put on then go from there
82.1st.gen [OP]
  • Turtle Points: 37
  • Male Posts: 52
« Reply #29 on: Nov 14, 2017, 10:42:21 AM »
Here's a little more trimmed up
