From the DMV site. 1. The new engine must come from the same kind of vehicle that the engine is going into. So a truck can only get an engine that was available in another truck. So a 2JZ swap will not be legal, ever.Sent from my Nexus 6P using Tapatalk
Ca is such a pain in the ass. Just go pay the extra $ for the "special" smog. Sent from my Nexus 6P using Tapatalk
Move
What part of CA are you in? I might have some interest Sent from my Nexus 6P using Tapatalk
ClassificationDon't mix engine and vehicle classifications which will degrade the emissions certification standards. For example, a heavy-duty engine cannot be installed in a light-duty exhaust-controlled chassis even if they have the same displacement. Non-emissions controlled power plants such as industrial or off-road-use-only engines may not be placed in any exhaust-controlled vehicle.
The best way to get the correct answer, would be to go into the local "referee" and speak to the ref who would be doing the inspection directly, he will tell you whether or not if the car engine into light duty truck is possible to do, if he says no, go to another ref, or ask to speak to his supervisor to get clarification.
As long as the engine is newer and has all of the smog equipment associated with the vehicle it was removed from it can pass CA referee.
That's what i thought to and i looked at the site before buying the engine. But another guy here has a 1uzfe from a newer model lexus ls-400 and they wont let it pass ref because its a car motor in a truck.
Exactly passenger car and light duty. You say truck and they go bonkers.
Now it seems like they are just making up stuff as they please. It does not state anything on ARB website about cooling system. Strictly states emissions and the fans have nothing to do with that.....wow just wow.....I'm still waiting for there call back and I am going to make some stuff very clear. Some of those refs are just book smart and not very vehicle knowledgeable. Most smog techs are that way as well. I worked with tons of smog techs that knew next to nothing about repairs and such. All they knew how to do was plug in the machine and the sniffer.Sent from my iPhone using Tapatalk
Finally got a call back from the ref. Here was his words. First he told me i cant use a manual transmission because that motor never came with a manual trans. I told him yes it i did, it came with a w-58 trans. He looked it up and told me i was correct, but if I'm going to use a manual trans than i have to get an ECU from a manual car, and then he told me it doesn't matter because i cant fit that motor in my truck with the cooling fan and fan clutch and that i wouldn't be able to use a electric fans because that motor comes from the factory with a fan clutch and fan, not electric fans. What any of that has to do with emissions i don't know. What does it matter if i use a manual trans ecu, or block the shift points in a auto ecu, and what cooling fans i use. Why does any of that make a difference for emissions? stupid California.
Started by Dr.Maxwe001 Toyota Pickup/4Runner Tech 1979-95
Started by Gadzooks Toyota Pickup/4Runner Tech 1979-95
Started by jrock « 1 2 » Engine
Started by IMMUDDY Project Research and Build-Ups
Started by 4runnerRob New Member Check-In!
