Author Topic: ToyBrota's 85 Xtracab Build up.  (Read 71814 times)
Toybrota
  • Turtle Points: 166
  • Male Posts: 764
  • Member since Dec '15
Re: ToyBrota's 85 Xtracab Build up.
« Reply #150 on: Nov 08, 2017, 05:08:53 PM »
Pull the selector hub off, one at a time, duct tape some plastic on, just to avoid debris, and go for a drive.
Good idea, I'll try this. Much appreciated :)
Toybrota [OP]
  • Male Posts: 764
« Reply #151 on: Nov 23, 2017, 12:56:57 PM »
Finished up my shift boots, I made one awhile ago and it was awful, so I redeemed myself.
Hand sewed, attached through the rubber boots base.
Lewis Hein
  • Shoutbox Ban
  • Turtle Points: 273
  • Member since Feb '17
« Reply #152 on: Nov 23, 2017, 04:04:20 PM »
Does the lock hub dial shift the transfer case?
Toybrota [OP]
  • Male Posts: 764
« Reply #153 on: Nov 23, 2017, 04:06:59 PM »
Ha I wish. It turns, but doesn't do anything.
Toybrota [OP]
  • Male Posts: 764
« Reply #154 on: Nov 23, 2017, 09:27:19 PM »
Ah, so the inevitable happened, my Motorcycle was stolen out of my driveway.
Looks like I'll be doing theft protection on my truck this weekend. I'll probably do the usual interrupter switch for the coil, they make keyed switches that I've seen at some autoparts stores.
That and hide it somewhere.
My main fear is that my truck is next.
Good news, I live in Salt Lake City, so I'm buying a Glock. Gotta protect my household somehow.
Lewis Hein
  • Shoutbox Ban
« Reply #155 on: Nov 24, 2017, 08:33:40 AM »
Sorry to hear about your motorcycle being stolen, but I'm glad you're thinking about theft protection for your truck. I can start any 81-89 Hilux or 4runner of this generation with a screwdriver and ballpoint pen, so I assume that a thief can, too.
If you wanted to get all fancy, you could set it up so that when the keyed switch activates the anti-theft system, turning the ignition switch to "start" blows the horn instead of cranking the engine. Furthermore: I can bypass any keyed switch with a knife and an alligator clip if the leads are in any way accessible. You've probably already thought of that.
Toybrota [OP]
  • Male Posts: 764
« Reply #156 on: Nov 29, 2017, 10:46:32 AM »
Going to be testing the reliability of my truck this next week, I'm embarking on a 800 mile journey (1600 round trip) to San Diego to see my mom.
I'm excited, but also a bit nervous. I have no reason to doubt my trucks reliability.
Over the last month, I've driven to Moab and back, and to Nevada and back. Both are about 1200 miles combined. And, with no trouble.
My truck does leak a bit of oil from the rear main, and burns a bit too. A compression test revealed 150 on all cylinders which is pretty good.
Any recommendations for things I should check or bring? I am gonna bring my tool set, enough tools to do a head gasket if needed.
I also have a spare belt and enough oil and coolant to kill an elephant.
And most importantly, I have some kicking tunes.
  • Online Silver Turtle Award
  • Turtle Points: 26852
  • Male Posts: 3,506
  • Member since Dec '10
« Reply #157 on: Nov 29, 2017, 11:01:54 AM »
It's going to run like a top  :thumbs:
Toybrota [OP]
  • Male Posts: 764
« Reply #158 on: Nov 29, 2017, 11:03:43 AM »
Ha thanks! That's the hope, I have had literally no issues with this truck, but it is my daily so I'm of course a little worried. My biggest concern is it being stolen, However I've taken care of that, it has a hidden keyed ignition switch.
  • Turtle Points: 452
  • Male Posts: 3,554
  • I'LL NEVER MAKE IT...
« Reply #159 on: Nov 29, 2017, 02:55:48 PM »
Bring a spare ignitor if you have one and a fuel filter wouldn't hurt.  Those two parts can strand you and the ignitor can be tough to get.
Toybrota [OP]
  • Male Posts: 764
« Reply #160 on: Nov 29, 2017, 02:56:52 PM »
Ignitor and fuel filter, I'll look into it.
Lewis Hein
  • Shoutbox Ban
« Reply #161 on: Nov 29, 2017, 03:07:07 PM »
Do the carb trucks have a fuel filter? I've searched in vain for one on mine...
One other thing I carry with me always is an alternator. I was once on a paleontology expedition where one pickup's alternator went out in the field miles from help; If we hadn't had other vehicles and had been further in the boonies, that could have been bad.
Beyond that, definitely an ignitor; A bad ignitor has stranded me before. Maybe also a fuel pump unless yours is a reasonably good shape OEM one.
Good luck and safe travels!
Toybrota [OP]
  • Male Posts: 764
« Reply #162 on: Nov 29, 2017, 03:11:55 PM »
Thanks! The fuel filter is next to the gas tank, under the truck bed. Just follow the fuel filter neck and you'll find it!
Toybrota [OP]
  • Male Posts: 764
« Reply #163 on: Nov 30, 2017, 06:16:27 PM »
Picked up some stuff today!
Got a spare fuel filter (thanks for the recommendation)
Also upper and lower rad hoses, and a belt for the water pump and alternator.
And finally, another steering stabilizer as the one I put it 6 months ago is bad. Got it warrantied so that's good!
I also, got an oil pressure gauge, and found out that it is impossible to find the right threads for this thing, NO one has an adapter, not ace, not home Depot, no autoparts stores. Tomorrow I'm going to an actual hose supply, so hopefully they will have something, if not I found one online.
Tomorrow I'm picking up a set of 16 inch Tacoma wheels with some street-ish tires on them for my trip, that way I don't put high miles on my off road set.
I'll post pictures tomorrow.
Lewis Hein
  • Shoutbox Ban
« Reply #164 on: Nov 30, 2017, 07:44:15 PM »
One other thing I thought of (that you may have thought of): Check drain plugs on engine, transmission, and differentials. I say this because my dad used to own a Ford Courier, but the transmission plug fell out on a highway trip, and he didn't know about it until the transmission was toast. (Then he bought a Toyota).
This failure mode is probably rare, but ever since hearing that story I try to check my drain plugs occasionally. They have never shown any hint of coming loose, but it's a quick and simple check that might someday save a bunch of money and hassle.
OK, my $0.02 are fast becoming $2. Hope it's useful, though.
Toybrota [OP]
  • Male Posts: 764
« Reply #165 on: Nov 30, 2017, 09:51:12 PM »
Definitely is a useful comment, this is super simple and often overlooked, I'll definitely be doing this.
An alternator might get left out, changing one of them not on the side of the road is a pregnant dog, like draining and removing the radiator kind of pregnant dog.
My battery holds a great charge (Optima sealed battery) and I have a new alternator, so charge problems are (should) be out the window.
I'm legit bringing an entire set, of tires with me. If anything, I feel like a tire failure is what would happen.
My main, and Biggest concern is theft, especially so close to the border. My truck does have a hidden (well hidden, I might add) kill switch. Which is also keyed too, so even if it's found they can't really start it. The coil isn't even powered from the main ignition circuit, so tearing the steering column apart would do nothing.
I do however have a pretty expensive sound system in my truck, subwoofer, fosgate speakers... I really don't want that stolen.
Toybrota [OP]
  • Male Posts: 764
« Reply #166 on: Dec 02, 2017, 04:08:28 PM »
Went on the local classifieds and found a set of base model Tacoma wheels with some highway tires on them, I didn't really see the need in using my nicer AT's on my other wheels.
I actually think they look pretty nice, they are a 16 inch rim, I might keep them. Or sell them....
I had to run an inch wheel spacer up front though.
300k
  • Turtle Points: 3744
  • Male Posts: 623
  • Member since Jun '15
  • GREEN NAME MAN BAD!
    • Please ban me!
          OK!
      I am banned!
« Reply #167 on: Dec 02, 2017, 04:18:07 PM »
this thing is looking pretty rad. you need to finish the look with the Skys crawler springs or RUFs so the axle is moved way forward :gap:
Toybrota [OP]
  • Male Posts: 764
« Reply #168 on: Dec 02, 2017, 04:19:25 PM »
Thanks! My actual mod that's happening next is High steer, I can't stand how awful and dangerous this steering is, I just don't have the welding know-how to do it :/
  • Online Gold Turtle Award
  • Turtle Points: 5134
  • Male Posts: 4,225
  • Member since Jun '16
  • 4-wheeling vicariously.
« Reply #169 on: Dec 03, 2017, 05:53:03 AM »
.... I can't stand how awful and dangerous this steering is ....
Are you referring to the Toyota stock steering, or your truck's specific steering?  :dunno:
When you say "dangerous", do you mean dangerous because it's defective, or dangerous for some other reason?  :dunno:
Gnarls. :inthedark:
Toybrota [OP]
  • Male Posts: 764
« Reply #170 on: Dec 03, 2017, 08:16:21 AM »
Gnarls. :inthedark:
It's the stock push-pull setup, with a dropped drag link. If I step on the brakes it pulls to the right.
85Buckett
  • Turtle Points: 187
  • Male Posts: 55
  • Nothing Happens Until Something Moves
« Reply #171 on: Dec 03, 2017, 09:13:28 AM »
Did you relocate your torque rod or is it at a steep angle?
Pirate 4x4 S/N  Tripower389
Toybrota [OP]
  • Male Posts: 764
« Reply #172 on: Dec 03, 2017, 09:14:56 AM »
Didn't relocate it, no way to fabricate anything at the moment
redneckcustoms13
  • Turtle Points: 7674
  • Male Posts: 2,513
  • Member since May '15
« Reply #173 on: Dec 03, 2017, 10:54:09 AM »
So is it an aftermarket drop arm or a stock one at a steep angle like 85bucket says
01 double cab hunting truck
06 tacoma street truck
  • Male Posts: 4,225
« Reply #174 on: Dec 03, 2017, 03:02:54 PM »
Interesting....
The only stock Toyota steering failure I had on both my 1986 IFS and 1985 straight axle, was a bent tire tie rod
from going airborne about 10 feet in Mexico on the beach at about 55 MPH.  :smack:
The other failure was on my 85 on Pritchett Canyon, I backed up gently with the wheels cranked too far over on
a slight incline and busted the knuckle arm. It was totally my stupidity!  I had a spare and had it fixed in about
20 minutes. :disturbed:
I did not have a drop drag link on either trucks.  :shake:
I 4-wheeled many years on some of the most difficult rock crawling trails in AZ, CA, NM, and UT, with Toyota factory front steering system.  :driving:
I have never had any of my trucks pull the steering due to the factory stock steering.  Other than the Detroit Locker in the front diff and hubs locked that was the normal behavior, I never once felt any danger or problems with the Toyota factory steering.  I have had a steering pull because of a brake disc issue.  :blah:
I guess I have just been lucky.  :gap:
I’ve not heard of Toyota factory early truck steering design referred to as “push-pull”.  I thought push-pull is a steering technique while driving.  I always thought Toyota’s early truck steering system design is a basic tie rod,
pitman arm, shock damper, and recirculating ball bearing.  :dunno:
Gnarls. :inthedark:
« Last Edit: Dec 03, 2017, 03:15:33 PM by Gnarly4X »
Toybrota [OP]
  • Male Posts: 764
« Reply #175 on: Dec 03, 2017, 03:13:51 PM »
Interesting....
I have never had any of my trucks pull the steering due to the factory stock steering.  I never once felt any
danger and problems with the Toyota factory steering.  I have had a steering pull because of a brake disc issue.  :blah:
Gnarls. :inthedark:
Push-pull on how the steering box on Solid Axle Toyota's work in conjunction with the steering arm on the knuckle, it pushed it and pulls it for turning in which direction.
Toybrota [OP]
  • Male Posts: 764
« Reply #176 on: Dec 03, 2017, 03:15:49 PM »
Dropped Draglink from procomp, and the anti-wrap bar is completely stock.
I think the issue is that it's lifted, using an upgraded dropped Draglink but the anti-wrap bar is stock, no difference in it's length. So, when I push on the brakes it doesn't work like it should and it pulls. At least that's what I've gathered.
  • Male Posts: 4,225
« Reply #177 on: Dec 03, 2017, 03:24:09 PM »
I'm not saying your pulling issue is NOT the steering.
My 85 was lifted about 4" from stock.  Are you sure you don't have a front brake issue?
Toybrota [OP]
  • Male Posts: 764
« Reply #178 on: Dec 03, 2017, 03:30:18 PM »
I mean it's all entirely possible. On your truck was your torque rod or anti-wrap bar stock? I'm assuming you ran a dropped Draglink too.
I can go ahead and bleed the brakes, that would probably do something
  • Male Posts: 4,225
« Reply #179 on: Dec 03, 2017, 03:49:35 PM »
My 85 was stock steering, no drop drag link.
