Author Topic: What antifreeze to use???  (Read 16367 times)
Gnarly4X
  • Turtle Points: 5134
  • Male Posts: 4,274
  • Member since Jun '16
  • 4-wheeling vicariously.
    • Buy me some coffee
Re: What antifreeze to use???
« Reply #30 on: Feb 27, 2017, 10:57:07 AM »
..he told me that coolant isn't made the same way it used to be.
Is ANYTHING made the way it used to be?
Gnarls.
blackdiamond
  • Turtle Points: 1174
  • Male Posts: 5,060
  • Member since Dec '03
  • Crawlin with Marlin
« Reply #31 on: Feb 27, 2017, 11:07:15 AM »
Gnarls.
Ice cubes?
OVRAROK
  • Turtle Points: 26778
  • Male Posts: 3,523
  • Member since Dec '10
« Reply #32 on: Feb 27, 2017, 11:25:32 AM »
as An alternative to coolant, you could go with Evans cooling. Ran it in my 67.
Gnarly4X
  • Male Posts: 4,274
« Reply #33 on: Feb 27, 2017, 11:39:57 AM »
Ice cubes?
Nope... it used to be I'd have to take an ice tray out of the freezer...now I just push on the ice cube dispenser on fridge door.. and bingo... filtered ice cubes!!
Gnarls.
« Last Edit: Feb 27, 2017, 05:32:53 PM by Gnarly4X »
:)bestgen4runner
  • Turtle Points: 2120
  • Male Posts: 1,796
  • Member since Mar '16
« Reply #34 on: Feb 27, 2017, 12:16:53 PM »
I have used Evans before. Expensive if used in large capacity applications, I use it in My banshee. Works great.
Put it in and forget about it.
I am 1/5th of Perfect Fit
Gnarly4X
  • Male Posts: 4,274
« Reply #35 on: Feb 27, 2017, 12:20:22 PM »
It's your B-DAY!!!  ...... turned big 40?....  :beer:
No worries... I didn't peak until 42...  you should be good for at least a couple years!!  :thumbs:
Happy Birthday!!!!!!!!!  :dancing:
Gnarls.  :clap:
OVRAROK
  • Male Posts: 3,523
« Reply #36 on: Feb 27, 2017, 12:21:26 PM »
I liked the fact that is had almost a zero pressure. I could put piece of foil, where radiator cap would go. Less pressure, less problems. I have 2 gallons sitting on a shelf
:)bestgen4runner
  • Male Posts: 1,796
« Reply #37 on: Feb 27, 2017, 12:25:29 PM »
Agree, Its incredible stuff. If money is no object. I am not sure it can be beat.
I personally always recommend to My customers to use what the Vehicle came with on anything modern.
old school stuff green just work perfect.
emsvitil
  • Turtle Points: 7571
  • Male Posts: 3,561
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
« Reply #38 on: Feb 27, 2017, 04:46:26 PM »
I know the farmer I work for prefers 60/40 and Ehen I asked why he told me that coolant isn't made the same way it used to be.
water/antifreeze or antifreeze/water   ?
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
Mudder
  • Turtle Points: 3487
  • Member since May '15
« Reply #39 on: Feb 27, 2017, 05:11:43 PM »
60 antifreeze 40 water.
Gnarly4X
  • Male Posts: 4,274
« Reply #40 on: Feb 27, 2017, 05:57:19 PM »
The "old farmers" wrote the Almanac, so they must know something!
Gnarls.
MrBooyay
  • Turtle Points: 92
  • Male Posts: 52
  • Slow and steady
    • Buy me a cigar
« Reply #41 on: Feb 27, 2017, 06:35:33 PM »
Does anyone have an opinion on using zerex G-05? i'm running it in my 84 22r right now after blowing my radiator cap off last summer.
Gnarly4X
  • Male Posts: 4,274
« Reply #42 on: Feb 27, 2017, 06:47:33 PM »
Gee... I don't recall hearing or reading that someone blew their radiator cap off.  I would think that if your engine is heating up enough blow off a radiator cap, you'd know something is wrong before that.  And, whatever coolant you would use most likely would not fix that kind of over-heating problem.
Even straight undiluted tiger piss probably would not fix your over-heating issue.  :gap:
Gnarls.  :spin:
« Last Edit: Feb 27, 2017, 06:53:48 PM by Gnarly4X »
emsvitil
  • Male Posts: 3,561
    • emsvitil's album
    • Buy me a soda
« Reply #43 on: Feb 27, 2017, 06:53:31 PM »
I would think blowing the cap off would be a head gasket leak into the cooling system......
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
MrBooyay
  • Turtle Points: 92
  • Male Posts: 52
  • Slow and steady
    • Buy me a cigar
« Reply #44 on: Feb 27, 2017, 07:20:29 PM »
Gnarls.  :spin:
Well it was the original cap, the rubber gasket on the cap was almost none-existent, and if I had a leak I'm pretty sure I would have sen it when I flushed the thingl. It happened in stop and go traffic in 105 degree weather with the A/C blowing hard, so it didn't seem too far fetched that the cap burst, but maybe i'm wrong.
Gnarly4X
  • Male Posts: 4,274
« Reply #45 on: Feb 28, 2017, 03:11:04 AM »
Well it was the original cap, the rubber gasket on the cap was almost none-existent...
 :yikes: :shake:  Oh my gawd!!!   :willynilly:  What happened to periodic maintenance?   :screwy:
Gnarls.
MrBooyay
  • Turtle Points: 92
  • Male Posts: 52
  • Slow and steady
    • Buy me a cigar
« Reply #46 on: Feb 28, 2017, 08:17:55 AM »
Gnarls.
I know right?  :smack: lesson learned though. Did a full flush of everything after that just to ease my paranoia.
No ones answered my question though, any opinions of the G-05??
H8PVMNT
  • Turtle Points: 452
  • Male Posts: 3,554
  • I'LL NEVER MAKE IT...
« Reply #47 on: Feb 28, 2017, 12:28:12 PM »
I run 60/40 here because I have had 50/50 slush up at 30 below F while driving.  I am using the Napa in house brand green stuff because it tastes better than all the other brands I've tried.
« Last Edit: Feb 28, 2017, 02:58:20 PM by H8PVMNT »
– Steve McQueen
Snowtoy
  • Turtle Points: 1403
  • Male Posts: 2,583
  • Member since Sep '03
« Reply #48 on: Feb 28, 2017, 03:15:12 PM »
Seen a rad cap on a Chevy do the same thing, the seal was gone and the spring was worn, which allowed it to rattle loose, than boom.
Given Ford's and Chrysler's reliability, not sure I would want to run anything designed to run in their vehicles. :laugh:  It probably works just fine, but with it being a different color you likely shouldn't mix it, so if you are going to go through the process of flushing the system, you might as well and run Toyota Red.
:)bestgen4runner
  • Male Posts: 1,796
« Reply #49 on: Feb 28, 2017, 04:07:38 PM »
So So smart! :thumbsup:
MrBooyay
  • Turtle Points: 92
  • Male Posts: 52
  • Slow and steady
    • Buy me a cigar
« Reply #50 on: Mar 01, 2017, 11:20:22 AM »
I did flush it, but the only reason I really went with the G-05 was because I was working at Napa at the time and got a good discount on it, if they carried the Toyota red i would have been all over it. I'll probably be changing out my radiator before it heats up again so maybe I'll flush it and go with the red this time.
sassparilla_kid
  • Turtle Points: -9
  • Male Posts: 67
  • Member since Feb '17
« Reply #51 on: Mar 02, 2017, 12:00:46 PM »
I'm thinking of going with Evan's on the 22re I'm gonna be rebuilding soon
'86 4X4 turbo turd pickup (soon to be non-turbo)
'17 Tacoma SR 4X4 (access cab, 4cyl, 5 speed)
mudmaster
  • Turtle Points: 3749
  • Male Posts: 2,855
  • Member since Feb '05
« Reply #52 on: Mar 02, 2017, 12:16:19 PM »
You have to completely flush any and all water from the system before you use Evans.
Time to go wheelin!
sassparilla_kid
  • Turtle Points: -9
  • Male Posts: 67
« Reply #53 on: Mar 02, 2017, 02:31:02 PM »
That's why I'm thinking of using it after the rebuild, everything will already be taken apart and cleaned out, easier to make sure the block is dry while it's out, so I'll just have to drain the radiator and blow all the water out of it and I'll be set
Mudder
« Reply #54 on: Mar 02, 2017, 02:33:06 PM »
You also have the heater core and all the hoses going to it to clean as well.
emsvitil
  • Male Posts: 3,561
    • emsvitil's album
    • Buy me a soda
« Reply #55 on: Mar 02, 2017, 04:48:55 PM »
I wouldn't put the Evan's in until I was sure everything was good.............  (first start with water)
« Last Edit: Mar 02, 2017, 11:04:29 PM by emsvitil »
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
sassparilla_kid
  • Turtle Points: -9
  • Male Posts: 67
« Reply #56 on: Mar 03, 2017, 07:37:37 AM »
I gotcha, well it'll be a while before I get there, so there's a good chance I'll change my mind by then anyway
Last post Oct 15, 2006, 02:53:39 PM
by Plowking
Last post Dec 10, 2006, 08:02:06 PM
by chaseheadrick
Last post Oct 30, 2007, 10:22:16 AM
by dothemonkey
Last post Jan 10, 2010, 09:41:07 PM
by ronezrocky
Last post Feb 03, 2011, 07:01:50 PM
by 79coyotefrg
