Author Topic: Head light upgrade on 84 4runner question  (Read 3139 times)
Jarhead
  • Turtle Points: 435
  • Member since Jul '12
« on: Feb 18, 2017, 12:31:58 PM »
So I finally got fed up with the yellow headlights on my 84 4runner so I decided I wanted to convert the headlights to an LED conversion. Well easier said than done. The H4 conversion that I got is not a plug and play that they said it was. I want to be able to have the low beam and high beam option but the way it the connectors are it doesn't give me an option for the high beam and it looks like the high beam is turned on all the time.
Has anyone done this to there 4runner if so can you guys shed some insight as to what I need to do to get it working properly? Any advise would be greatly apprishiated.
Congill77
  • Member since Nov '16
Re: Head light upgrade on 84 4runner question
« Reply #1 on: Feb 19, 2017, 04:12:35 PM »
Can you post some pictures of the new connectioners?
Jarhead [OP]
« Reply #2 on: Feb 21, 2017, 12:01:13 PM »
The black one is the new one.  I guess I worded this wrong, the connectors are plug and play but when I turn the lights on all I get is the high beam. The low beam doesn't work and I don't want to be that whole in the street blasting everyone with my high beams.
mudmaster
  • Turtle Points: 3687
  • Male Posts: 2,847
« Reply #3 on: Feb 21, 2017, 12:40:22 PM »
Hmmmmm. The ones I got for my 83 were plug and play as were the LEDs I installed??
Time to go wheelin!
gnob
  • Turtle Points: 486
« Reply #4 on: Feb 22, 2017, 09:32:33 AM »
You may have to do a headlight harness like 4crawlers.
hold this. . .
Snowtoy
  • Online The 2.5K Group
  • Turtle Points: 1403
  • Male Posts: 2,583
  • Member since Sep '03
« Reply #5 on: Feb 22, 2017, 04:04:03 PM »
Can you get the low beams to work when connected directly to the battery?
Jarhead [OP]
« Reply #6 on: Feb 22, 2017, 09:56:44 PM »
I've seen lots of post about the headlight harness upgrade. But unfortunately no one says where they have gotten there's at. I have also seen that there are sites that say I need to use the negative switch harness to get this to work correctly, but all the harnesses I have found say nothing about the negative switch harnesses. I've tested the stock plug and I do see when I turn on the head light the negative actually activates the low beam and also the high beam in the connectors. So the negative switch harness makes sense. I almost want to try to make my own, but I know not having the connectors it will not look as nice as if I bought the harness Pre-made.
  • Turtle Points: 7571
  • Male Posts: 3,561
    • emsvitil's album
Jarhead [OP]
« Reply #8 on: Feb 22, 2017, 11:26:00 PM »
The harnesses that I have been looking at all have dual relays.
gnob
« Reply #9 on: Feb 23, 2017, 06:34:05 AM »
It needs two relays.
Toyota wires their headlights back asswards from everyone else.
hold this. . .
ArloMyles
  • Member since Jan '17
« Reply #10 on: Mar 04, 2017, 08:50:51 PM »
Ive been looking to upgrade my headlights on my 85 4runner too!
Last post Nov 22, 2004, 04:38:55 PM
by 2utadud
Last post Mar 09, 2006, 11:13:51 PM
by Rocksurfer
Last post Aug 28, 2007, 09:28:24 PM
by 85yodaon33s
Last post Oct 11, 2007, 09:35:30 PM
by Mistaken
Last post Feb 07, 2010, 09:51:36 PM
by 83yota5960
