Author Topic: #turdburglar  (Read 8451 times)
seebrookmeyer
  • Turtle Points: -51
  • Male Posts: 48
  • Member since Jul '16
Re: #turdburglar
« Reply #30 on: Aug 31, 2020, 11:53:48 AM »
Rather than deal with trimming away the existing spring hanger and cleaning up what was there from the previous bumper, decided it would be best to just lop the front 16" of the stock frame off. This also gets the frame about 2" higher than stock and should net me some more favorable up travel numbers. I am planning to push the front axle forward a few more inches than what was there before which should get the 39's out of the way of the firewall. Next up is to finish welding and plating the frame rails and get the motor set back in place to start mocking up motor mounts.
seebrookmeyer [OP]
  • Male Posts: 48
Re: #turdburglar
« Reply #31 on: Nov 09, 2020, 09:55:21 AM »
continuing to crawl along...
Got the axle back from Rear End Specialities last week. ARB and 5.38's are set up and installed. Installed the shafts and hydro assist ram to verify clearances for steering. Need to tack the truss back in place but otherwise the axle is ready to get mocked up under the truck.
Fit up the frame plates for the outside and bottom of the frame rails. These plates came from 4WU but needed a bit of love to make them fit and tie in with the new section of frame. got the motor and transmission back in position and ready for mounts to be fabricated. Once I have a landing spot for the frame side motor mounts, I will mock up some additional fish plates for the top and inside frame rails where the 2x3 frame mates to the existing frame.
seebrookmeyer [OP]
  • Male Posts: 48
Re: #turdburglar
« Reply #32 on: Nov 23, 2020, 08:00:55 AM »
Motor and transmission are back in. I don't love the mounts that came with the FROR T case crossmember. There is a fairly large span between the motor mounts and the T crossmember so once the links are in I may try to come up with another crossmember that can tie into the front side of the skid. that being said, I'm not the first person to run this crossmember so it will probably work just fine. Pretty happy with how the motor mounts came out and should be plenty strong enough for that powerful 22re...
  • Turtle Points: 4256
  • Male Posts: 3,546
  • Member since Jun '16
Re: #turdburglar
« Reply #33 on: Nov 24, 2020, 04:36:09 AM »
When read and see these posts and nice photos I’m somewhat envious of the skill, talent, tools, time and money that goes into that type of fabrication.  It really does look awesome!
However, it looks structurally overkill and very heavy to me. :disturbed:
I 4-wheeled very actively (2 to 4 weekends a month) for almost 20 years. I wheeled some the hardest rockcrawling trails and challenging terrains in California, Utah, New Mexico, Arizona and Sonora Mexico.
My old pickup was mostly stock: 3200 lbs. 1985 Toyota pickup 22R Standard Cab, straight axle, Marlin Crawler t-case, 5-speed, 4” lift, Detroit locker rear and Lock Right in the front, 4:10 R&Ps, and 33” muds.
I only broke about 4 times as I remember – a J-arm on Pritchett Canyon (my fault – I backed up with wheel cranked too hard – my spare was on in less than 20 minutes), and a rear leaf spring (I had a repair clamp on in 10 minutes).  I tore the rear diff drain plug on the Dusy Irshim (it was welded up in about 15 minutes by Ray Currie).  And, the driver's side motor mount broke in Moab on the Moab Rim (I had a piece a chain and bolted it on in about 15 minutes).  I never punctured a tire and had only minor to moderate body damage.  After terrorizing the rocks on trails on weekends, I drove it back and forth to work 5 days a week.
I guess I could say I was really lucky. :dunno:
Gnarls. :blah:
« Last Edit: Nov 24, 2020, 04:59:54 AM by Gnarly4X »
seebrookmeyer [OP]
  • Male Posts: 48
Re: #turdburglar
« Reply #34 on: Nov 26, 2020, 06:48:24 AM »
I can promise you it doesn’t just look heavy... it is!
seebrookmeyer [OP]
  • Male Posts: 48
Re: #turdburglar
« Reply #35 on: Dec 03, 2020, 10:20:49 AM »
got the axle under the truck with the 39's to begin figuring out where its going to live. currently set with a 120" wheelbase (previously 118") and about 5 1/2" of available up travel. Should be a fun time packaging everything in there.
seebrookmeyer [OP]
  • Male Posts: 48
Re: #turdburglar
« Reply #36 on: Dec 14, 2020, 07:33:43 AM »
Frame side panhard bar mount is tac'd in with an EMT panhard hard for the time being. making some progress on setting bump stop locations, driver side is integrated with the panhard mount. Pushed that assembly back as far as possible in an attempt to make some more room for the steering box and pitman arm. Drag link is going to be a chore to stuff in there and will probably need to clearance the frame to make it fit (I know I should just go full hydro). Need to get the passenger side bump mocked up and start cycling and checking clearances. Upper link mount has a cozy home between the frame rail and the oil pan. A little concerned that it may hit either of those when articulating so going to need to spend some time figuring those clearances out.
seebrookmeyer [OP]
  • Male Posts: 48
Re: #turdburglar
« Reply #37 on: Dec 16, 2020, 07:40:11 AM »
Bumps are set. Drag link is just laying in there, at full bump it "fits". It will come down a bit on the driver side once it is actually set in place as its currently sitting on top of the pitman arm. End of the day I will likely need to notch the frame to make room.  need to spend some time getting the steering box in it's new home and see where all the components will actually land. I have both a flat and drop pitman arm so I have some different options.
The towers I purchased with the 4WU kit are not going to work. Since I pushed the axle forward from the intended location with this kit they are pretty much in the way of everything, steering, bumps, panhard mount, you name it, it interferes with it. I order some 1.5" hoops from RuffStuff which should be a much cleaner solution. So if anyone wants some unwelded cobra towers from 4WU let me know.
seebrookmeyer [OP]
  • Male Posts: 48
Re: #turdburglar
« Reply #38 on: Jan 14, 2021, 01:40:55 PM »
Full hydro components should arrive from PSC tomorrow. If someone is looking for a 8" stroke PSC hydro assist ram and a tapped toyota IFS steering box let me know. Passenger side shock hoop is mocked up. Need to clearance the fender well some more but overall I'm pretty happy with the "adjustable" shock hoop. Made things pretty easy to get set up in a happy place. Will build an engine crossover brace to support the top of the mounts and provide me with a location to mount the resi's on. Picking up the cab over camper this weekend so i will likely be throughly distracted for a bit.
