Author Topic: W56 Noise Diagnosis  (Read 3220 times)
jbramble24
  • Member since Nov '16
W56 Noise Diagnosis
« on: Dec 16, 2016, 07:32:09 AM »
Hello again.
I am hoping you kind folks can help me figure out the noise my truck is making. It sounds like bearing noise/whirring/clatter similar to how my input shaft bearing sounded at idle before I replaced it. It is only heard while decelerating and moving. If I give it even a touch of throttle, the noise stops. When I press in the clutch while decelerating, the noise also stops.
The truck is a 93 4x4 22re with newly rebuilt motor, new clutch, flywheel, pilot bearing, throw out bearing, master and slave cylinders (all factory aisin / nachi parts). It has a w-56 forward shift trans with new input shaft bearing and countershaft bearing. Running redline mt-90 fluid in it and dino 75w90 in the transfer case. The trans internals looked ok to my untrained eye when I had it apart. No chipped teeth and reverse looked a little worn but all shifts fine.
Part of me says not to worry about it until something breaks but the obsessive part of me wants to know what it is.
Thanks!
jbramble24 [OP]
Re: W56 Noise Diagnosis
« Reply #1 on: Dec 22, 2016, 06:21:55 AM »
I removed the rear driveshaft and took it for a spin and did not hear the noise. This leads me to believe I have a bad pinion bearing. Unless I can find a cheap used 3rd member, it looks like I'll be ordering a new one.
  • Turtle Points: 26739
  • Male Posts: 3,523
  • Member since Dec '10
« Reply #2 on: Dec 22, 2016, 06:29:51 AM »
do you know the gear ratio?  shouldn't be hard to find a 3rd
jbramble24 [OP]
« Reply #3 on: Dec 30, 2016, 08:44:33 AM »
It's 4:11. I looked around on eBay but I'd rather have a new one for a couple hundred dollars more. I hate doing things twice but I usually end up doing so if I take a shortcut.
:)bestgen4runner
  • Turtle Points: 2120
  • Male Posts: 1,796
  • Member since Mar '16
« Reply #4 on: Dec 30, 2016, 05:34:44 PM »
Local wrecking Yard. around $100 4.11 is By far the most common gear ratio. In a stock application this is not a part that fails often. Exceptions being abuse, neglect, or improper setup from the factory.
Nothing wrong with craigslist also.
Unless money is not a concern because then I say go buy a brand new factory one from your local Toyota dealer. $700 +
 :twocents:
I am 1/5th of Perfect Fit
  • Turtle Points: 5134
  • Male Posts: 4,271
  • Member since Jun '16
  • 4-wheeling vicariously.
« Reply #5 on: Dec 31, 2016, 02:49:05 AM »
jbramble24,
So you have eliminated the rear drive shaft as a potential cause of the "noise"??
jbramble24 [OP]
« Reply #6 on: Dec 31, 2016, 05:43:39 AM »
I replaced the u-joints and had the driveshaft checked and rebalanced (to 0.25 oz or less) by a driveline shop so it should be squared away.
Toyotas and jeeps are scarce in my local yards but I will look around. I'm starting to think this truck had way more than 190k on the clock! It was probably not well maintained either.
I'm not setting this truck up to crawl, but instead to be my daily driver so reliability is important. I drive ~80 miles round trip to work with occasional snow/ice. I have a Tacoma prerunner but it's rather squirrely in the snow with no weight on the back.
Thanks for the replies fellas! I'll do an intro thread and fill in the details on my latest money pit.
Last post Dec 03, 2004, 02:57:59 PM
by Mike D
Last post Sep 10, 2006, 09:52:56 PM
by Duffil
Last post Nov 14, 2006, 05:24:23 PM
by flipskid
Last post Jun 14, 2008, 09:53:24 AM
by Dr.Maxwe001
Last post Nov 10, 2012, 06:47:58 PM
by finisher424
