Is there a tranny filter inside the filter?
What would you like me to comment on?
Can't read it, download a higher resolution copy.............
https://docs.zone/pdf-to-jpgDon't need to sign up for 1 page.Then you'll have a jpg to upload....
My buddy has a BMW It has lifetime oil thats supposed to be changed every 40,000.I would change every 20,000 in my own stuffIve seen what the crap out of clutch packs can do to the oil and valvebodies.I would only use genuine Toyota filters. Even if the filter for an A650E is $160.Accirding to my transmission building budddy the only difference between Dexron 3 and type 4 atf is an additive which is available form lube gard
The difference is the friction modifiers. I have used the Lubegard stuff for many years not and it works well until you have synthetic trans fluid dex VI, Mercon Lv or Sp. Also i have noticed the Lubegard with Dex 3 does not last as long and tends to break down faster.While i dont have any documentation its all personal experience, 10 years of experience in trans rebuilding & R&R.
Started by toyotaboy Parts Wanted
Started by tazulica Parts For Sale
Started by Rocksurfer Transmission/Clutch
Started by jmsdad Parts For Sale
Started by Talongod Transmission/Clutch
