Author Topic: 22re no start help  (Read 8099 times)
Tcyota
  • Member since Sep '15
22re no start help
« on: Oct 21, 2016, 05:26:15 AM »
I know this subject has been discussed but I couldn't find the thread when I searched. '87 Toyota 22RE. Getting fire, getting fuel, double and triple checked the timing. Can spray gas into throttle body but still no fire. I put an EFI relay on, swapped the ECU. Need help please and thanks in advance.
Could it possibly be that the valves need adjusting?
  • Turtle Points: 5134
  • Male Posts: 4,272
  • Member since Jun '16
  • 4-wheeling vicariously.
Re: 22re no start help
« Reply #1 on: Oct 21, 2016, 06:52:16 AM »
There are basically three things needed to fire a cylinder.
Gotta have a sufficient fuel/air mixture, gotta have sufficient compression, and you gotta have sufficient spark.
How did you test for spark?
How did you test for fuel?
Did you do a compression check?
Does the engine act like it tries to fire?
The valve lash would have to be way off in nearly valve for you not to be able fire an engine.
Did it suddenly not start or has some work been done to it before the problem?
« Last Edit: Oct 21, 2016, 07:43:32 AM by Gnarly4X »
Mudder
  • Turtle Points: 3487
  • Member since May '15
« Reply #2 on: Oct 21, 2016, 06:52:52 AM »
MAF, Fuel pump? Idle screw all the way in? How did you check the timing without it running? Any codes?
:)bestgen4runner
  • Turtle Points: 2120
  • Male Posts: 1,796
  • Member since Mar '16
« Reply #3 on: Oct 21, 2016, 02:46:51 PM »
Gnarls Gnarls Gnarls  :headshake:
One more Time By the Book. Properly timed Hot spark, Proper air fuel ration, Compression , And proper ??????? ?????.
There are actually 4 things.
Fill in the blank please.
I am 1/5th of Perfect Fit
  • Male Posts: 4,272
« Reply #4 on: Oct 21, 2016, 04:32:12 PM »
Well... the firing order has to be correct, right?  So, the plug wires will need to be in the right order from the disty to the spark plugs - 1-3-4-2.
:)bestgen4runner
  • Male Posts: 1,796
« Reply #5 on: Oct 21, 2016, 04:52:04 PM »
Nope that's Part of the properly "timed" hot spark.
Guess again.
  • Male Posts: 4,272
« Reply #6 on: Oct 21, 2016, 06:00:33 PM »
Guess again.
Well... of course the crankshaft has to have proper rotation speed, right? :dunno:
My ASE Certification has expired! :yikes:
Gnarls. :gap:
:)bestgen4runner
  • Male Posts: 1,796
« Reply #7 on: Oct 21, 2016, 06:04:06 PM »
Gnarls. :gap:
Good Job Gnarls!  :yesnod:
  • Male Posts: 4,272
« Reply #8 on: Oct 22, 2016, 03:34:09 AM »
I just need some erudite injected certitude.  :smokin:   And...Tcyota needs some fire in his injected cylinders!  :attention:
Gnarls. :spin:
« Last Edit: Oct 22, 2016, 03:43:53 AM by Gnarly4X »
Tcyota [OP]
« Reply #9 on: Oct 22, 2016, 07:43:52 AM »
Checked fuel by cracking fuel line at the filter and at the cold start injector. Check spark by just pulling plug and turning motor over. Motor does not try to fire. I check timing by bringing 1 tdc both # 1 vavles was loose then check distributor
Tcyota [OP]
« Reply #10 on: Oct 22, 2016, 09:24:36 AM »
Ok I did a compression check it #1 showed 60psi the rest was less than 50psi. I traded for this thing not running and it looks like they have put a head on it. Don't know if it ran after the head was put on. I know that 60 psi is not good what could cause the low reading ? Besides just wore out need help thanks .       And my compression tester is new but from harbor freight ?   :hammerhead:
Tcyota [OP]
« Reply #11 on: Oct 22, 2016, 09:48:48 AM »
Also put some oil in cylinders and it did not change psi much at all.
  • Male Posts: 4,272
« Reply #12 on: Oct 22, 2016, 10:06:51 AM »
Well, I don't think 60 lbs is enough compression to fire the mixture.
Snowtoy
  • Turtle Points: 1403
  • Male Posts: 2,583
  • Member since Sep '03
« Reply #13 on: Oct 22, 2016, 11:22:03 AM »
Try adjusting the valves then check comp. again.
With engine at 5* BTDC, the dist, should look like pic #2 when installed.
Tcyota [OP]
« Reply #14 on: Oct 22, 2016, 01:55:03 PM »
I also checked the injector pulse with noid light and I am getting no fire to the injectors
  • Male Posts: 4,272
« Reply #15 on: Oct 25, 2016, 07:51:06 AM »
Qué pasa??
:)bestgen4runner
  • Male Posts: 1,796
« Reply #16 on: Oct 25, 2016, 09:08:02 AM »
I suspect the valve timing is off if all cylinders have low compression and oil made no difference.  :turtle3:
  • Male Posts: 4,272
« Reply #17 on: Oct 25, 2016, 09:55:43 AM »
How far off would the valve timing have to be to have low compression in all cylinders?
Gnarls. :inthedark:
  • Male Posts: 4,272
« Reply #18 on: Oct 25, 2016, 09:58:58 AM »
Tcyota,
Did you check the cam timing?
Last post Feb 22, 2003, 04:07:53 AM
by BigMike
22RE won't start
Last post Sep 27, 2005, 06:36:54 AM
by RHG
Last post Feb 01, 2006, 11:08:04 AM
by toymech
Last post Aug 19, 2012, 05:18:51 PM
by Royota
Last post Aug 05, 2016, 01:59:39 PM
by Gnarly4X
