Author Topic: Rear Axle Swap  (Read 2932 times)
MrBooyay
  • Turtle Points: 92
  • Male Posts: 52
  • Member since Mar '16
  • Slow and steady
    • Buy me a cigar
Rear Axle Swap
« on: Oct 20, 2016, 09:34:33 PM »
I've got an 84 xtra cab wit ha 22r and I was looking on craigslist for some toyota parts and some guy is sellin a rear axle off a 96' Tacoma v6, is that an easily do-able swap with just a flange adapter or somethin? Or is there a better option out there?
OTO Phil
  • Turtle Points: 1018
  • Male Posts: 682
  • Member since Jan '16
  • Owner of Offroad Toy Outfitters
    • Offroad Toy Outfitters
    • Buy me a soda
Re: Rear Axle Swap
« Reply #1 on: Oct 20, 2016, 10:50:29 PM »
Why do you want to swap axles? Is yours bent or something?
Sent from my LG-H830 using Tapatalk
Mudder
  • Turtle Points: 3487
  • Member since May '15
Re: Rear Axle Swap
« Reply #2 on: Oct 21, 2016, 06:54:58 AM »
The IFS rear is wider than the SFA trucks rear axle by about 3". What you want is the rear axle from an 86-95 unless you don't mind fabing stuff up so the E-brake fits correctly.
MrBooyay [OP]
  • Turtle Points: 92
  • Male Posts: 52
  • Slow and steady
    • Buy me a cigar
Re: Rear Axle Swap
« Reply #3 on: Oct 21, 2016, 07:16:37 AM »
No, I just remember reading somewhere that there were some later model rear axles that were a little beefier than stock 84's and I wanted a kind of "practice" axle so I could do some other upgrades on it like disc brakes, gears and such without having to take off my current axle. It's my daily driver and I'm pretty much self taught on everything with this truck so sometimes it takes me a little while to do things the first time around and I can't have it torn apart for more than a weekend.
MrBooyay [OP]
  • Turtle Points: 92
  • Male Posts: 52
  • Slow and steady
    • Buy me a cigar
Re: Rear Axle Swap
« Reply #4 on: Oct 21, 2016, 07:17:45 AM »
Alright cool, I'll keep an eye out for that then. Does it matter if its a 6 cyl or 4 cyl?
Mudder
Re: Rear Axle Swap
« Reply #5 on: Oct 21, 2016, 07:39:20 AM »
It really doesn't. But you do want to get the mounting plates that the U-bolts go though unless you flip the U-bolts when you swap rear axles.
MrBooyay [OP]
  • Turtle Points: 92
  • Male Posts: 52
  • Slow and steady
    • Buy me a cigar
Re: Rear Axle Swap
« Reply #6 on: Oct 21, 2016, 07:56:19 AM »
Awesome, thanks for  your input
Beastcrawler85
  • Member since Dec '16
Re: Rear Axle Swap
« Reply #7 on: Jan 16, 2017, 07:20:53 PM »
V6 has a stronger carrier
redneckcustoms13
  • Turtle Points: 7674
  • Male Posts: 2,513
Re: Rear Axle Swap
« Reply #8 on: Jan 18, 2017, 06:24:26 AM »
Also that 96 axle would be from a tacoma that is 3" wider than a wide trac which is 3" wider than a sfa truck. Basically you would be looking at your rear wheels sticking out 3" on each side since the taco axle is 6" wider than your existing
01 double cab hunting truck
06 tacoma street truck
Last post May 10, 2004, 12:19:13 AM
by WHITE_TRASH
Last post Apr 17, 2006, 12:43:17 AM
by cheap sunglasses
Last post Mar 14, 2009, 12:54:09 PM
by bgiffie
Last post Jul 01, 2014, 01:15:16 PM
by 1985CRAWLER
Last post May 30, 2016, 06:18:05 PM
by schadenfreude
