http://www.lceperformance.com/ARB-4-Cylinder-Bearing-Kit-p/2051702.htm
Got to ask?Why no longer able to be converted
My ARB is old. Very old
Some different info on the bearings: shows different OD's, but has a solution.http://www.pirate4x4.com/forum/toyota-truck-4runner/1188977-4-cyl-6-cyl-carrier-bearing-interchangeability.html
Call Arb ask them if it's possible. Every time I have asked them questions they have been great.
I think the 45mm and 50mm have the same OD.......Seehttp://gearinstalls.com/bearing.htm (scroll down just a little)I then checked some parts at rockauto.Use a 91 pickup with V6.The 45 and 50mm bearings were only different in ID...I know you can use a 6cyl carrier in the 4cyl case. You only had to change to the 6cyl (50mm) bearings.Looks like the opposite is possible.......
Started by cgbemis Engine
Started by CTENG in KS Engine
Started by BoG-ToY Parts For Sale
Started by NorCalToy General 4WD Discussion
Started by Dunnerway Transmission/Clutch
