Author Topic: Drive shaft relenght?  (Read 912 times)
nando707
  • Turtle Points: 35
  • Male Posts: 8
  • Member since Jul '16
  • International 4x4, 4runner
« on: Jul 21, 2016, 08:48:55 PM »
Should i have my rear drive shaft shorten or extended if i  moved the rear axle of my 4runner about 1 and half  inches forward after the leaf swap?
Dingman.
  • Turtle Points: 1125
  • Male Posts: 3,448
  • Member since Oct '08
Re: Drive shaft relenght?
« Reply #1 on: Jul 21, 2016, 09:05:21 PM »
If you move your axle forward 1.5" you will more than likely need to shorten the driveline.  Otherwise it will most likely bottom out.  If you move the axle back you may need to lengthen it.  You only have so much slip available.  Too long of a driveline will bottom out and too short of a driveline you risk it pulling apart.  I generally always tried to make standard toyota rear shafts 1.5" from bottoming out at ride height.
Last post Aug 14, 2006, 08:47:58 PM
by 89YOTER
Last post Aug 29, 2006, 07:47:06 PM
by ddement
Last post Mar 12, 2007, 07:42:05 AM
by MiniSimp
Last post Mar 20, 2008, 09:03:58 AM
by FIREBALL
Last post Aug 22, 2008, 09:08:59 PM
by Mnmstoy
