Author Topic: Pulling a forward shift Tcase  (Read 2272 times)
300k
  • Turtle Points: 3744
  • Male Posts: 623
  • Member since Jun '15
  • GREEN NAME MAN BAD!
    • Please ban me!
          OK!
      I am banned!
« on: Jul 04, 2016, 04:05:51 PM »
Hello  Marlin community, recently I snapped the threads off my transfer case fill hole. Looking at it, it appears to be an easy fix after dropping the case out of the truck. Further investigation into chiltons and the FSM, you "have" to drop the transmission as well.
I am one person armed with a socket and wrench set, a floor jack, and a PDF version FSM. Dropping the transmission is exactly what I don't want to do, so I ask if it's possible to drop a forward shift setup without dropping the trans? I hear it's perfectly fine doing it with a top shift setup.
Mudder
  • Turtle Points: 3487
  • Member since May '15
Re: Pulling a forward shift Tcase
« Reply #1 on: Jul 04, 2016, 04:15:05 PM »
I don't see why you couldn't. Just remove the shifter handle base and pull the transfer case back to remove it.
  • Turtle Points: 26739
  • Male Posts: 3,523
  • Member since Dec '10
« Reply #2 on: Jul 04, 2016, 04:16:20 PM »
You'll be fine, just make sure you pull the shifter before. Part should be there Wednesday
:)bestgen4runner
  • Turtle Points: 2120
  • Male Posts: 1,796
  • Member since Mar '16
« Reply #3 on: Jul 04, 2016, 04:22:32 PM »
Hey, bro
You do not have to remove the transfer case.
Just replace the rear t-case cover in the truck.
Its so easy you will be shocked.
I have done this several times when Younglings have checked fluid level and overtightened the plug.
I the Mechanics world this is know as "Grave Grave". It means easy money.
I am 1/5th of Perfect Fit
  • Male Posts: 3,523
« Reply #4 on: Jul 04, 2016, 04:25:24 PM »
I would run a 2x4 in the interior with a tie down strap, to support transmission, then UN bolt crossmember from frame, use floorjack to get right to that sweet spot so you can slide rearward, pull down, don't forget rear driveshaft.
300k [OP]
  • Male Posts: 623
    • Please ban me!
          OK!
      I am banned!
« Reply #5 on: Jul 04, 2016, 05:50:46 PM »
I think the previous owner threw it on with an impact gun!
I was hoping to GUNK the whole tcase, but if I don't need to pull it I'll just do as you said.
xhootiehoox
  • Turtle Points: 180
  • Male Posts: 109
  • Member since Feb '16
  • Be like water just flow with it
« Reply #6 on: Aug 22, 2016, 07:16:49 AM »
Smartest thing I have ever done even when stabbin a trans use the 2x4 method and it makes it cake
The secret is more beer and better music 🇺🇸
Last post Sep 10, 2005, 12:00:36 AM
by toyoder
Last post Mar 01, 2007, 05:54:50 AM
by KToy
Last post Jan 09, 2008, 07:11:49 PM
by kneedownnate
Last post Feb 19, 2010, 11:14:15 PM
by toyotamobing
Last post Dec 19, 2014, 08:12:36 AM
by Erick561
