Whats this?
Looks like t case. With PTO
Ok, well it's definitely aisin. Gonna guess r series. Offset rear diff, bellhousing looks to be diesel?
Was searching for something and came across this old jew. BUMP to a classic thread
Offset rear end from a land cruiser?
Looks like an r series tranny with a split case on it. .. found in newer cruisers. 1990 something and newer
Lots of jdm pto takeoffs out there. . You can generally pick one up for around 500 bucks. .. the issue is that sometimes the drive gear in the tcase won't be there for the pto so you will need to split the case open and install that as well. ..
Would you run a PTO Winch or a hydraulic pump off it?
So if your going 8274 its definitely not gonna be for a pto winch. What would you need a hydraulic pump for?
You could mount a Hiab crane!
I really want one of those winches
I've done some research on them for a few old 8274 I have laying around.
The shipping is killer though.
Those were our 1st and 2nd gen sr5 wheels. I love those
Ours were 15x7
Started by freds40 General 4WD Discussion
Started by kcowyo New Member Check-In!
Started by busmup808 Rig Gallery
Started by T.Rex New Member Check-In!
Started by rayota New Member Check-In!
