Type 2-A Carb 4Cyl Installed 8/1983 to 4/1984 Forward Shift, 4.5" Offset Shifter Block Off Plate Tall Style Case 10mm Flange Bolts Quiet Run Gears No Bearing Retainer Clip 21 Spline Input 27 Spline OutputsType 2-B Carb 4Cyl Installed 4/1984 - 8/1988 Forward Shift, 4.5" offset Shifter Block Off Plate Tall Style Case 10mm Flange Bolts Quiet Run Gears With Bearing Retainer Clip 21 Spline Input 27 Spline Outputs
Thanks man... Sure wish i'd read your reply this morning as I'm now the proud owner of a W56-C and transfer case from an '89... LOL. With my luck it'll turn out to be a U-joint after all... Even though I checked them and they're all tight with no slop or wiggle, but who knows, maybe the driveline was a bit bound up at that point...Anyway, I suppose I could always re-sell the W56 if I don't need it. Or, maybe I'll just install it anyway. After all, it's an "upgrade" and a stronger tranny, right?as for interchange - According to Marlin's bible, the early forward shift trannys & t-cases had 4.5" for what's called "offset". Later ones like this one I just bought only have 4". I won't know anything for sure 'til I drop the tranny that's in the truck and compare it with this one I just bought, but my guess is that the shifter is in a slightly different location, probably 0.5" further back on the tranny and thus the shift forks are a little shorter, which would mean you can't easily interchange these t-cases. Also, it looks like Toyota just kept the same housing casting while changing other stuff as this t-case on the W56-C has a place to mount a shifter in the top-shift position, it's just blocked off with a plate. Makes me think it might be possible to convert a top-shift t-case to forward shift, and vise-versa to match the transmission you're going to use it with.
Started by jktoy Toyota Pickup/4Runner Tech 1979-95
Started by T Pennington Toyota Pickup/4Runner Tech 1979-95
Started by motoracer « 1 2 » Toyota Pickup/4Runner Tech 1979-95
Started by toyotaman83 Transfer Case/Drive Line
Started by Gnarly4X « 1 2 ... 93 94 » Chit Chat Camp
