Author Topic: Clicking/knocking from rear differential?  (Read 5891 times)
PeterPaul383
  • Turtle Points: 98
  • Male Posts: 36
  • Member since Oct '15
« on: Apr 19, 2016, 07:30:18 PM »
Hey guys, so another thing on my truck has broke or is about to break  :tantrum:. Right when I got my truck back up and running, I started to get this knocking/clicking noise from the rear axle. I noticed a faint clicking noise before about 2 weeks ago but my fuel pump broke so I forgot about it while I was fixing my fuel pump. So after I got it towed home and fixed the fuel pump, I went to go drive it today and now it is making a bad clicking noise from the rear end. I lifted the back end up and spun the tires to see if I could pin point the area the noise was coming from and it seems to be coming from the rear diff. The clicking gets faster the faster I spin the tires. Any idea what it might be?
redneckcustoms13
  • Turtle Points: 7674
  • Male Posts: 2,513
  • Member since May '15
Re: Clicking/knocking from rear differential?
« Reply #1 on: Apr 19, 2016, 08:14:59 PM »
Could be bearings, could be a broken gear (spider gear or ring/pinion) have you checked the u joints for slack? Might get lucky. Also does the pinion have any slack in and out or up and down? If so you will need to have that diff rebuilt.
01 double cab hunting truck
06 tacoma street truck
PeterPaul383 [OP]
  • Turtle Points: 98
  • Male Posts: 36
« Reply #2 on: Apr 19, 2016, 08:21:05 PM »
I tried to wiggle the drive shaft but it was pretty solid. It only spun. I will check tomorrow and see if it moves in and out.
  • Turtle Points: 2872
  • Male Posts: 8,707
  • Member since Sep '05
« Reply #3 on: Apr 19, 2016, 08:41:24 PM »
is it possible something near the fuel tank is loose, or hitting the driveshaft? I know sometimes I have been working on something else, get it back together and have a new problem, but it was jsut a loose skidplate or something that I forgot (or a backing plate on the brakes that got smacked or something and now rubs)
redneckcustoms13
  • Male Posts: 2,513
« Reply #4 on: Apr 20, 2016, 05:25:34 AM »
How far did the drive shaft turn with the truck in gear?
PeterPaul383 [OP]
  • Turtle Points: 98
  • Male Posts: 36
« Reply #5 on: Apr 20, 2016, 09:42:06 PM »
I haven't checked how far the drive shaft spun in gear. I will have to check that tomorrow as well as whether the pinion has any slack.
Bent 85
  • Turtle Points: 38
  • Member since Apr '16
« Reply #6 on: Apr 24, 2016, 04:15:24 PM »
Heard funny noises coming from mine, tore it down and found a chipped ring and pinion. Cost me but now it's fixed.  :smack:  Hope you find better things in yours.
« Last Edit: Apr 24, 2016, 08:36:05 PM by Bent 85 »
Plainview
  • Turtle Points: 175
  • Member since May '14
« Reply #7 on: May 07, 2016, 08:41:00 PM »
I had your exact symptoms and found this today...
DSC_1403 by Will Baker, on Flickr
DSC_1400 by Will Baker, on Flickr
'84 Xtra Cab Project:
http://board.marlincrawler.com/index.php?topic=100651.new#new
Parts Wanted:
- Un-cracked dash pad (do they exist?)
Last post Jun 09, 2005, 05:28:40 PM
by Rocksurfer
Last post Oct 03, 2006, 09:59:36 PM
by Weldo
Last post Oct 08, 2006, 04:57:06 PM
by i_luv_my_truck
Last post Jun 04, 2007, 02:51:37 PM
by MiniSimp
Last post Mar 04, 2017, 08:40:50 PM
by ArloMyles
