Author Topic: Idle issues  (Read 2354 times)
jessroseblackpearl
  • Member since Mar '16
Idle issues
« on: Mar 12, 2016, 03:24:36 PM »
 :smack: :smack: 1987 4 Runner XLT-- aka the black pearl
Hello Oh Jedi Masters...
I need some help... Having an issue with idle in neutral and while the clutch is depressed (while changing gears and while taking out of gear). At running temp, it revs up anywhere between 1500 and 3+ RPM. I have put in new throttle cable, adjusted valves, adjusted idle, and replaced TPS... Pheww... I have an 87, but my 88 that I rolled this fall was doing the same thing. It feels mechanical but I'm stuck.... Lay it on me I'm listnin... Thanks in advance.
OTO Phil
  • Turtle Points: 1018
  • Male Posts: 682
  • Member since Jan '16
  • Owner of Offroad Toy Outfitters
    • Offroad Toy Outfitters
    • Buy me a soda
Re: Idle issues
« Reply #1 on: Mar 13, 2016, 03:37:48 AM »
Did you tune the TPS while the throttle body was still installed? When I replaced mine, I didn't remove the TB, and it ran like crap... I took off the TB and tuned it again, and it was off about a degree, but upon re-install of the TB, it ran perfectly.
You might also want to check for any vacuum leaks... spray a tiny bit of brake cleaner or starting fluid around the intake in small doses, and you might find an intake leak somewhere... Mine was on my IACV.
Good luck!
  • Turtle Points: 1088
  • Male Posts: 9,757
  • Member since Oct '04
Re: Idle issues
« Reply #2 on: Mar 14, 2016, 10:09:30 PM »
Stupid questions, but does it still rev high when you remove the throttle cable, and have you adjusted the idle screw on the throttle body?
Last post Mar 18, 2006, 01:22:53 PM
by Plowking
Last post Sep 27, 2006, 09:57:33 PM
by Duffil
Last post Jan 27, 2021, 03:48:10 PM
by Stiffer_22
Last post Nov 29, 2009, 10:33:50 PM
by poolfixr
Last post Feb 16, 2022, 11:18:55 AM
by Gnarly4X
