Author Topic: New B T-Case Question  (Read 3665 times)
rlm007
  • Member since Feb '16
« on: Feb 29, 2016, 07:04:31 AM »
I just picked up a 1984 Yota with double case. if I do not move the forward shift first the crawl case pin falls out or the rails when I shift the crawl case shifter.  It seems that I do have a option for two wheel drive.  I am missing something here?
« Last Edit: Mar 02, 2016, 12:46:24 PM by rlm007 »
OVRAROK
  • Turtle Points: 26739
  • Male Posts: 3,522
  • Member since Dec '10
Re: New B T-Case Question
« Reply #1 on: Feb 29, 2016, 07:27:30 AM »
sounds like nobody cut the drivers side shift rail on the rear case, or if you are referring to twin sticks on rear case, there is a center pin between rails that needs to be removed in order for twin stick set up to operate properly
« Last Edit: Feb 29, 2016, 07:38:00 AM by ovrarok »
rlm007 [OP]
« Reply #2 on: Feb 29, 2016, 01:16:36 PM »
Its the Passenger side that is not moving, the Driver side moves.
redneckcustoms13
  • Turtle Points: 7674
  • Male Posts: 2,513
  • Member since May '15
« Reply #3 on: Feb 29, 2016, 05:11:18 PM »
So are you saying that you have a dual case set up with twin stick shifter in the rear case? When you say forward shifter. Is this a forward shift front case or a top shift case?
01 double cab hunting truck
06 tacoma street truck
rlm007 [OP]
« Reply #4 on: Feb 29, 2016, 07:49:52 PM »
It's a forward shift
jangelfire
  • Turtle Points: -1
  • Member since Jan '15
« Reply #5 on: Feb 29, 2016, 08:17:27 PM »
So thats your crawlbox, a.k.a front case.this is strictly a gear reduction shifter.2wd/4wd is shifted in your rear case.without a twin stick in the rear case you dont have the option for 2wd lowxlow.
rlm007 [OP]
« Reply #6 on: Mar 01, 2016, 09:19:49 PM »
I was told it's a top shift
  • Turtle Points: 2872
  • Male Posts: 8,707
  • Member since Sep '05
« Reply #7 on: Mar 01, 2016, 09:31:38 PM »
wait, you say,
so which is is? can you take a picture of it? would help people out......
OTO Phil
  • Turtle Points: 1018
  • Male Posts: 682
  • Member since Jan '16
  • Owner of Offroad Toy Outfitters
    • Offroad Toy Outfitters
    • Buy me a soda
« Reply #8 on: Mar 02, 2016, 03:10:28 AM »
 :worthless:
 :thumbs:
rlm007 [OP]
« Reply #9 on: Mar 02, 2016, 12:32:31 PM »
I will try to post some pics tonight.  I got a hold of the previous owner and he said the back stick high and low, the front stick is high low and two wheel drive.  So the J Pattern is the Front stick not the Back stick.  is this possible???
OVRAROK
  • Male Posts: 3,522
« Reply #10 on: Mar 02, 2016, 12:52:10 PM »
no, you need to remove the section of the transfer case that has the front drive flange in order to install the adapter, the most rearward case will have 2wd/4wd, (4hi/4lo). front case is strictly hi/lo
redneckcustoms13
  • Male Posts: 2,513
« Reply #11 on: Mar 02, 2016, 04:16:56 PM »
Like he said it is impossible for the front shifter to do anything other than just make a straight pattern from high to low. The rear case will have the j pattern if it only has a single shifter. If someone has installed a twin stick in the rear case it will be high and low on the left stick and 2wd to 4wd on right stick. You can't post pictures yet you don't have enough posts. Pm me the url from your photobucket and ill post them if you'd like.
jangelfire
  • Turtle Points: -1
« Reply #12 on: Mar 02, 2016, 08:46:35 PM »
Heres mine and it cant work any other way.
Last post Mar 15, 2004, 02:34:47 PM
by BigMike
Last post Oct 11, 2004, 09:23:26 AM
by 4DEES
Last post Nov 01, 2004, 11:33:59 AM
by BigMike
Last post Jan 23, 2007, 01:25:14 PM
by Boheefus
Last post Aug 26, 2009, 12:14:22 AM
by havik
