the only one on earth who wants to run a chain case
Started by Kyle N, February 15, 2016, 03:44:08 PM
Kyle N
So I SAS'd my Tacoma using FJ80 front/rear axles. Already have dual gear cases that I put together recently with the marlin 23 spline set. BUT I did not want dual gear cases. I only went there because it is the most common thing to do. Reason being is that the chain cases have 30 spline outputs, slightly shorter low range and they are a dime a dozen. Not to say gear cases arent reasonably inexpensive. Yeah I know the aftermarket for them is crap.
So I wish to accumulate the necessary 12 posts to put up a wanted ad. Lol. I doubt I'd ever run across an adapter but it's worth a shot. Oh, I am running pass-side drop. When it comes down to it, I probably should have just spent 800 and bought a LH drop housing and stuffed the 80 axle guts in it and ran a Tacoma dual set. Yeah, Marlin sells a adapter set but the several times I inquired on it, I got no response. I dont see it listed individually.
