Toyota1 has really nice kits. Includes Pistons .020-.060, pin bushings, Hastings chromoly rings, brass freeze plugs, steel guide timing set, new timing cover, oil pump, bearing set, and a complete gasket set for $279. Add 4 resized rods for $75 there bead blasted then resized with new pin bushings installed and pin fit to you exact pistion pins and weight matched. Re ground crankshafts are $129. 1230 11th. St. Modesto ca. 95354 (209)toyota1 (209)869-6821 209toyota1.com
