Author Topic: rear axle and locker.  (Read 1696 times)
84_yota_4wd
  • Turtle Points: 219
  • Male Posts: 831
  • Member since Feb '06
  • mountain goat
    • Buy me some coffee
« on: Jan 06, 2015, 05:49:05 PM »
Hi everyone. I have an 84 pickup and am running 529's and a lock rite locker. I run 35" tires as well. I have a rear axle from an 89 4runner I would like to get under my truck. I was considering dropping my differential in it and rolling but lately mine as been making loud bangs when I accelerate.  As well as there is alot of play when you turn the pinion.
If I'm going to rebuild one I'm leaning towards the v6 diff
I really like the idea of a selectable locker.
Do the e lockers from the Tacomas work in a 89 v6 diff?
If not would my lock rite fit in the v6 diff?
What your guys thoughts on this?
Also what locker would you run on a budget. This is a daily driver
Thanks Mitchell :turtle:
Marlin Crawler
Developers of the longest lasting and most successful
Toyota Transfer case, Transmission, and Differential products on the planet
(888) 94-CRAWL / 888-942-7295
zippo
  • Turtle Points: 550
  • Male Posts: 1,557
  • Member since Nov '08
    • oppiz.net
If you see it, its for sale.
84_yota_4wd [OP]
  • Male Posts: 831
  • mountain goat
Re: rear axle and locker.
« Reply #2 on: Jan 06, 2015, 11:27:57 PM »
That is an excellent write up on how to build a third member thanks. I bookmarked it.
What would you do build the ifs v6 third or rebuild my 84 4 cyl third.
Also the lock rite might be ok in mine.
But I am leaning towards a selectable locker but am on a budget. That's why I was curious about the tocoma e lockers
Marlin Crawler
zippo
  • Male Posts: 1,557
    • oppiz.net
« Reply #3 on: Jan 06, 2015, 11:42:38 PM »
The 6cly uses larger bearings I might check a junk yard see if you could get a good core on the cheap and build it. I would go with an ARB or factory e-locker.
Also look at http://www.gearinstalls.com/
zuk is the end all on toyota diffs. You might email him and ask what he would do.
84_yota_4wd [OP]
  • Male Posts: 831
  • mountain goat
« Reply #4 on: Jan 06, 2015, 11:45:34 PM »
I have a complete ifs 6 cyl axle I'm gunna swap for the wider track witdh. It's a good axle.
So if I understand you my lock rite should fit in both ?
And the e lockers from tocos fit as well?
Marlin Crawler
84_yota_4wd [OP]
  • Male Posts: 831
  • mountain goat
« Reply #5 on: Jan 06, 2015, 11:54:14 PM »
What do you think of yukon zip lockers they look fairly reasonably priced
Marlin Crawler
4-lo
  • Turtle Points: -80
  • Male Posts: 752
  • Member since Dec '05
  • build tonite crawl tomorrow
« Reply #6 on: Jan 07, 2015, 10:23:43 AM »
They both are 8" diffs. The e locker will fit into the any toyota 8" housing with Some modification, you will have to grind, drill and tap the ifs housing to fit the e locker.
It will be a score for you if you can find a axle that is already been done for e locker or even better a full float elock housing.
« Last Edit: Jan 07, 2015, 10:30:12 AM by 4xsports »
4-lo
  • Male Posts: 752
« Reply #7 on: Jan 07, 2015, 10:27:01 AM »
Havent yet ran into any issue with them yet.  Just as good as an arb.
zippo
  • Male Posts: 1,557
    • oppiz.net
« Reply #8 on: Jan 07, 2015, 12:22:01 PM »
Watch this before you do anything
https://www.youtube.com/watch?v=dyzyAVPTM8c
84_yota_4wd [OP]
  • Male Posts: 831
  • mountain goat
« Reply #9 on: Jan 07, 2015, 12:47:17 PM »
Wow. That's a heck of a test. Arb it is then. Unless I can find an e locker. Thanks for the useful info.
Marlin Crawler
Last post Sep 09, 2008, 08:04:44 AM
by jryota
Last post Jan 12, 2009, 07:36:01 PM
by shnipe
Last post Oct 10, 2008, 06:34:28 PM
by E YOTA
Last post Dec 06, 2011, 12:03:30 PM
by H8PVMNT
Last post Sep 13, 2016, 12:40:29 PM
by Lizard_lips
