Author Topic: 4.88 8in, 4cyl Ring & Pinion $130 Shipped from Fort Lauderdale, FL  (Read 2274 times)
coryc85
  • Trade Count: (0)
  • Turtle Points: 55
  • Male Posts: 93
  • Member since Sep '05
4.88 Ring and Pinion 8in, 4cyl variety, just removed from my truck.  Seem to be in good shape, but unknown overall mileage.  Will also include a new pinion seal from the Trail-Gear setup kit, a new pinion nut, and a crush sleeve.  Could also throw in the used bearings if you want them.  From reading Zuk's website, the markings lead me to believe these are the old Genuine Gear brand gears.  These were set up with an .081 pinion shim, which I can also include if you'd like, but I did not check the pattern to verify that it was correct, although the gears were not loud or anything.
Markings on the pinion
Markings on the ring gear
coryc85 [OP]
  • Trade Count: (0)
  • Turtle Points: 55
  • Male Posts: 93
BUMP, still have these gears.
superyota
  • Prestige Worldwide
  • Trade Count: (+2)
  • Turtle Points: 71
  • Male Posts: 3,362
  • Member since Oct '05
  • what happened?
    • Placer County Crawlers
Is this a factory 4.88 set?  If so, I'm interested.
ABD Motorsports
#4475
www.placercountycrawlers.com
KK6QDW
coryc85 [OP]
  • Trade Count: (0)
  • Turtle Points: 55
  • Male Posts: 93
Superyota - no I'm 100% certain these are not factory 4.88s and I'm about 80% sure they are genuine brand gears.  Zuk's webpage says that the only markings normally on the genuine gears are the stamped Toy 488.
superyota
  • Trade Count: (+2)
  • Turtle Points: 71
  • Male Posts: 3,362
  • what happened?
Oops. Thanks for the clarification.  I should have read your entire post.
Thanks.  Bump for ya.
ABD Motorsports
#4475
KK6QDW
coryc85 [OP]
  • Trade Count: (0)
  • Turtle Points: 55
  • Male Posts: 93
BUMP....still have these gears.  Also open to trades.
BPINAZ
  • Trade Count: (0)
  • Turtle Points: -49
  • Member since Jul '10
Is it just the one set, or is this for two ring gears and two pinion gears? Thanks.
If you're gonna be dumb, you better be tough. I've got the scars to prove it
coryc85 [OP]
  • Trade Count: (0)
  • Turtle Points: 55
  • Male Posts: 93
Sorry, just a single ring and pinion.
coryc85 [OP]
  • Trade Count: (0)
  • Turtle Points: 55
  • Male Posts: 93
Bumppy!
Wouldn't mind trading for a new(ish) 22re radiator, maybe some poly body bushings for 4Runner.
coryc85 [OP]
  • Trade Count: (0)
  • Turtle Points: 55
  • Male Posts: 93
Bump to help me spend more money on my truck!
Last post Jan 18, 2004, 09:32:19 AM
by loubell
Last post Apr 05, 2009, 09:04:27 PM
by yotaismygame
Last post Sep 18, 2011, 10:18:49 PM
by Jaysen
Last post Jul 01, 2012, 02:44:20 AM
by zembalayan
Last post Sep 10, 2012, 07:41:07 AM
by coryc85
