Author Topic: 22re rebuild  (Read 1251 times)
b_sherwood3
  • Trade Count: (0)
  • Male Posts: 31
  • Member since Sep '11
22re rebuild
« on: Feb 23, 2012, 03:48:38 AM »
This is a 22re engine built with quality aftermarket parts to produce around 165-175 hp. Factory 22re produces 112hp. I had the block cleaned, checked for cracks, bored .40 and honed at METS engine shop in lafayette, It has a new crank shaft, new bearings, new piston rods from Lc engineering, New rocker arm assy toyota factory, new kieth black high compression pistons and rings from Lc engineering, and a new performance head with oversize stainless stell valves with the performance cam from Engine builders, new brass freeze plugs. This engine was built from the ground up, for performance and quality. All parts are toyota factory or a higher grade replacement. Not many parts are better then the orginal toyota parts except for some of the upgrades offered by Lc engineering, and engnbldr.com. You can look at these web sites and to price the parts on this motor. You can also price a motor like this and I promise you, you will not find one cheaper. The upgrade will also allow you to install a supercharger or turbo if you would like to. Call Brent @3372900110 if interested. I am selling for 1800.00.
« Last Edit: Feb 23, 2012, 03:58:57 AM by b_sherwood3 »
Last post Jun 01, 2005, 10:21:46 PM
by alfio
Last post Jul 05, 2006, 07:55:19 PM
by 79coyotefrg
Last post May 22, 2007, 08:44:53 AM
by Zoomschwortz
Last post Dec 13, 2007, 04:08:02 PM
by 84pickup
Last post Jun 22, 2010, 02:37:06 PM
by gtoyonrocks
