The reason is because the output from the crawl box (in low range) has multiplied the torque going into the rear case. If you have 2.28 gears in front, it's less torque being applied to the rear case input than when you have 4.7 gears in front. Less torque on the rear input means less chance of breaking any of the rear case's components.
