Author Topic: HELP PLEASE HELP, MY ONLY DD WONT RUN  (Read 1516 times)
BoG-ToY
  • Turtle Points: 594
  • Male Posts: 2,122
  • Member since Dec '05
« on: Feb 16, 2011, 08:16:41 PM »
Ok, so my 87 22re 4runner wont run right, it was almost instant.....
when I start it, it spins up an sounds good then sputters to a quit, If I feather the pedal just right I can almost make it run and sound good.... otherwise it sounds like its leaning out or flooding
no codes
swapped TPS, checked AFM.... possibly injector issues? has good spark
CHECK THIS, while playing around not doing anything... my injectors were clicking weird (possible it just landed on the wrong spot on the distributor?) almost sounded like an arc but you could feel the injectors clicking with the sound
Sand, what fun, drop pressure to 12psi, stock tires are still digging, can't afford to get stuck, 8psi, still not working. Find a place to GET OUT, air up, un-lock hubs,  WAIT whats this, hubs are UN-LOCKED already. 2wd, 8psi, stock tires, Oregon sand dunes.
86bobbedtoy
  • Turtle Points: 686
  • Male Posts: 3,938
  • Member since Oct '06
Re: HELP PLEASE HELP, MY ONLY DD WONT RUN
« Reply #1 on: Feb 16, 2011, 08:33:37 PM »
with your fingers open your mass air flop box, while someone tryes to start it
also check the intake tube for rips or tears
BoG-ToY [OP]
  • Male Posts: 2,122
« Reply #2 on: Feb 16, 2011, 09:04:23 PM »
no rips or tears... it will idle now,
kinda, codes 5 and 12
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
« Reply #3 on: Feb 16, 2011, 09:31:26 PM »
Code 5 ---- OX sensor signal
Code 12 --- Knock control sensor signal
BoG-ToY [OP]
  • Male Posts: 2,122
« Reply #4 on: Feb 16, 2011, 09:37:49 PM »
sucks is its a newer O2 sensor.... and dunno bout the knock sensor
fade
  • Turtle Points: -9
  • Male Posts: 1,018
  • Member since Oct '09
86 mini truck 18" rays
09 highlander
70 suburban
BoG-ToY [OP]
  • Male Posts: 2,122
« Reply #6 on: Feb 16, 2011, 11:06:11 PM »
WET ECU dried it... works?
86bobbedtoy
  • Male Posts: 3,938
« Reply #7 on: Feb 16, 2011, 11:10:00 PM »
that will do it
BoG-ToY [OP]
  • Male Posts: 2,122
« Reply #8 on: Feb 16, 2011, 11:18:16 PM »
still has some issues, BUT I messed with TPS so its not adjusted
just a little lag when first pushing the pedal, so probably just the IDL switch not set right
Wont run right Help!
Last post May 28, 2005, 08:19:39 AM
by Uncle Jesse
Last post Sep 12, 2005, 06:14:38 PM
by Remotruker
Last post Nov 19, 2005, 12:46:58 PM
by kneedownnate
Last post May 10, 2006, 05:36:09 PM
by kneedownnate
Last post Dec 18, 2009, 10:05:08 PM
by SloCrawler
