Author Topic: steering column question.  (Read 1361 times)
BrianE
  • Member since Sep '10
« on: Dec 19, 2010, 07:44:52 PM »
I am doing a tilt swap for my truck. I have found a complete sr5 column but its supposedly for manual steering. Mine is power steering. Is there a difference in columns? I know the rest is pug and play. just would like to know if there is a difference in shafts or splines.
89 4x4 22re dlx pickup 5spd
81_yota
  • Turtle Points: -41
  • Male Posts: 299
  • Member since Apr '10
  • Parcore !
Re: steering column question.
« Reply #1 on: Dec 19, 2010, 07:55:26 PM »
no difference should be easy swapin
93REDCRAWLER
  • Turtle Points: 110
  • Male Posts: 563
  • Member since Nov '10
  • You see it we wheel it
« Reply #2 on: Dec 21, 2010, 08:56:30 AM »
X2
BrianE [OP]
« Reply #3 on: Dec 23, 2010, 07:53:39 PM »
thanks guys. also will the int wipers work or do i need to modify
81_yota
  • Male Posts: 299
  • Parcore !
« Reply #4 on: Dec 23, 2010, 08:10:36 PM »
depends on your hook up but idk you could mod it if needed shouldnt be to hard
flyinsquirel
  • Member since Dec '07
« Reply #5 on: Dec 27, 2010, 10:54:39 AM »
If you had int wipers before just be sure to use your levers on the new column if it has the non-int wiper lever.  If you didn't, but the new column does, you will also need the int wiper control box.  Small green box mounted under the passenger kick panel - I think that's were it was.
Last post May 30, 2005, 10:21:55 PM
by RustyToy
Last post Jan 24, 2006, 06:09:06 PM
by heep70
Last post Jun 24, 2008, 04:57:46 AM
by Tallchevy
Last post Feb 09, 2009, 06:55:17 PM
by Duffil
Last post Oct 20, 2009, 12:03:37 PM
by kneedownnate
