Author Topic: Front straight axle inner  (Read 1731 times)
wildcat
  • Member since Apr '10
« on: Apr 05, 2010, 04:33:40 PM »
Aloha all
I was installing a new front third member and found a metal ring floating on my inner axle any Ideas.
Thanks :help:
BLACKDOG
  • 3.0 Killer
  • Turtle Points: 718
  • Male Posts: 7,644
  • Member since Aug '04
  • I used to fit
Re: Front straight axle inner
« Reply #1 on: Apr 05, 2010, 04:58:51 PM »
Pictures certainly help.
Where was it?  What did the ring look like? It could be the clip that belongs in a groove at the splined end, designed to keep it in the differential.
The axle should have, or originally had baffles, but I  don't see how they could deteriorate or break apart to where they could be called a ring, rather than what they are.
              -Ronald Reagan
joey0712
  • Male Posts: 1,459
  • Member since Apr '08
« Reply #2 on: Apr 05, 2010, 05:11:11 PM »
The front housing doesnt have baffles.
91 Toyota High pinions f&r.
BLACKDOG
  • 3.0 Killer
  • Male Posts: 7,644
  • I used to fit
« Reply #3 on: Apr 05, 2010, 05:24:12 PM »
No?  The one I was going to put in my truck did.  :headscratch:  Thats the only one I've ever torn apart.
              -Ronald Reagan
joey0712
  • Male Posts: 1,459
« Reply #4 on: Apr 05, 2010, 06:12:16 PM »
Hm weird. I dont think so... the ones ive seen are welded in
88_Pathy
  • Turtle Points: 65
  • Male Posts: 1,251
  • Member since Oct '06
  • Raised suspension
« Reply #5 on: Apr 05, 2010, 06:19:20 PM »
Mine had hole in them?
wesley
  • Turtle Points: -1
  • Member since Mar '10
  • you gotta get a little mud on the tires
« Reply #6 on: Apr 05, 2010, 09:02:18 PM »
there is a c-clip that goies inside the birf joint that locks when you slide the inner and outer together. thats probably it. if you can yank your inner and outer shafts appart easily then i would say its deffinately it.
TheCookieMonster
  • Male Posts: 973
  • Member since Dec '07
« Reply #7 on: Apr 05, 2010, 09:07:43 PM »
either the c clip that holds the birf to the inner axle or the metal ring spring on the inner axle seals ? my guess would be an axle seal spring deal (not sure what those are called)
Last post Feb 06, 2005, 08:52:30 PM
by 90slvpup
Last post Nov 20, 2005, 12:20:53 AM
by RCRunner
Last post Nov 14, 2006, 11:13:12 AM
by usmcracing
Last post Oct 15, 2010, 10:27:22 AM
by motormouth559
Last post Mar 14, 2011, 11:10:01 PM
by possume22
