I did alll the way home hahah
I had this happen to me but my R151F was sitting on vertical on it's bell housing and what happens is the 5th gear is so heavy it just slides and then the shifter is stuck in neutral but it's in gear. What Marlin told me to do and I sure hope I remember this correctly cause it's been years...was to remove the reverse light switch on the side of the tranny and use some needle nose plyers and pull the shift fork or rod whatever it's called...backwards and that will put the transmission back into neutral.I'm not sure this is your case but it's something to ponder or try...GOOD LUCK!!
Started by rockrat Parts For Sale
Started by Redd Toyota Tacoma/4Runner/T100/Tundra/FJ Cruiser 1995+
Started by vang_toua_moua Transmission/Clutch
Started by redneckcustoms13 Parts For Sale
Started by SqWADoosh Transmission/Clutch
