The 4P wire is the signal from your speed sensor. It means 4 pulse as in 4 pulses per revolution. The green with orange wire goes from the spedo to the ECM. But there should be a Grean with light blue, and a pink with light blue wire that go form the speed sensor to the cluster.
When you say "But there should be a Grean with light blue, and a pink with light blue wire that go form the speed sensor to the cluster." Are talking 97 colors or 92 colors or both?
Are these wires coming from the E12, or H, plug of the ECM?
So essentially the wires run from the speed sensor, to the ECM.
Then from the ECM to the speedo via the Green/Lt. Blue and Pink/Lt. Blue wires, and then a single Green/Orange wire back to the ECM?
