Author Topic: Vented disk brake and wheel combo question  (Read 2166 times)
Larryb
  • Turtle Points: 3
  • Male Posts: 206
  • Member since Mar '09
« on: May 30, 2009, 05:34:14 PM »
My 85 4runner is due for a 4 wheel brake job. I am debating on converting the front brakes to a "vented" disk set up. I currently have the black rock crawler style wheels with 4" backspacing. Does anyone know off hand what size wheel spacers i would need to run to clear the calipers?
boggerunner
  • Turtle Points: 9
  • Male Posts: 3,140
  • Member since May '06
  • Philberbuilt
Re: Vented disk brake and wheel combo question
« Reply #1 on: May 30, 2009, 09:43:14 PM »
6v calipers can be ground down to fit, 4 cyl ifs calipers will fit fine.
Larryb [OP]
  • Turtle Points: 3
  • Male Posts: 206
« Reply #2 on: May 31, 2009, 07:07:54 PM »
Which is better to use? I am also going to upgrade my master cyl to the 1" bore version. Any ideas for a better bolt in brake booster while i am at it?
  • 96ZJ v8
  • Turtle Points: -415
  • Male Posts: 4,823
  • Member since Jun '07
    • Buy me a drink
« Reply #3 on: May 31, 2009, 07:15:30 PM »
any V6 truck 90-00 i think uses the same bolt pattern as the older trucks.
and they are Dual Diaphram.
bolts right up and will give you a much stiffer and firmer brake.
Larryb [OP]
  • Turtle Points: 3
  • Male Posts: 206
« Reply #4 on: May 31, 2009, 07:17:32 PM »
Cool, thanks for the info
  • 96ZJ v8
  • Male Posts: 4,823
    • Buy me a drink
« Reply #5 on: May 31, 2009, 07:20:18 PM »
if you go to a junk yard MOST should be able to cross reference for you.
I went in and asked for a 93-97 T100 4x4 Brake Booster and it came out of a 90-98 V6 4Runner.
and np :beerchug:
TacoRunner
  • Turtle Points: 19177
  • Male Posts: 2,324
  • Member since Feb '04
  • The 1st 3RZ swap 99'-01'
    • 4wheelunderground
« Reply #6 on: Jun 02, 2009, 08:22:39 AM »
The Taco stuff will bolt right up too. I've run that for about 10 years. Works great with vented disc's
www.4WHEELUNDERGROUND.com
info@4wheelunderground.com
  • 96ZJ v8
  • Male Posts: 4,823
    • Buy me a drink
« Reply #7 on: Jun 02, 2009, 11:32:34 AM »
even the Taco 4cyl stuff? I knew all V6's and T100's used the Dual Diaphram Booster
Vented Brake Rotors
Last post Jun 20, 2003, 04:11:09 PM
by brainlessfool
Last post Jul 12, 2003, 09:20:59 AM
by vikingsven
Last post Jan 10, 2006, 03:01:36 PM
by KWP
Last post Jul 23, 2007, 11:37:38 AM
by Tallchevy
Last post Jul 12, 2010, 09:18:39 AM
by BigMike
