When I put longer shackles on my truck, I just moved the lower mount (axle) up by how much I gained.
If you gained 5 inches, just add a bar to up the mount 5 inches..........
You could use a longer bar, and drill extra holes so you can play with adjusting the rear line pressure (less length = less rear brakes, more length = more rear brakes)
